Results 1 to 4 of 4
Thread: INPUTS - 12V Volts <> 5 Volts
    Dec 2007
    Victoria, Australia
    Question INPUTS - 12V Volts <> 5 Volts
    Is this correct:
    If you supply a voltage creater than 5V to board you will damage it?
    If you what board to act as voltmeter, must you use a Voltage Divider to ensure the max input doesnt exceed 5V - does the brain then convert and display 5V as being full battery charge?
    FusionFormDynamic.skin doesnt show any processing?
    #STARTNEW#
    #NAME#Battery
    #TYPE#VOLTAGE
    #VIDPID#MyBrain0
    #MULTILEVELGRAPHICS##0,4.3#\Black Skin\Analogue Graphs\Battery\Bar0.png;\Black Skin\Analogue Graphs\Battery\Bar1.png;\Black Skin\Analogue Graphs\Battery\Bar2.png;\Black Skin\Analogue Graphs\Battery\Bar3.png;\Black Skin\Analogue Graphs\Battery\Bar4.png;\Black Skin\Analogue Graphs\Battery\Bar5.png;\Black Skin\Analogue Graphs\Battery\Bar6.png;\Black Skin\Analogue Graphs\Battery\Bar7.png;\Black Skin\Analogue Graphs\Battery\Bar8.png
    #SIZE#92,144
    #LOCATION#133,19
    #SHOWTEXT#false
    #PAGE#0
    #PORT#1
    #BORDERSIZE#0
    #PLOTLENGTH#100
    #HISTORYSIZE#250
    #ENDNEW#
    thanks peter
    Fusion Brain Creator
    Mar 2005
    I will reply to the hardware portion, Nick can reply to the software scaling.
    If you source more than 5vDC to the analog input, you will damage the PIC.
    The easy solution is a voltage divider.
    The better solution is an Op-Amp.
    Both are available with examples on Wikipedia.
    Mar 2006
    Colorado, but Canadian!
    I dont understand your software question...
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    Quote Originally Posted by 2k1Toaster View Post
    i think he wants to know how to scale voltage inputs
  1. How-To: Modifying the PW200
    By evandude in forum Power Supplies
    Last Post: 08-18-2005, 06:45 AM
  2. Opus 120w wiring help.. 2 ground and 12v inputs??
    By jedi7001 in forum Power Supplies
    Last Post: 06-13-2005, 12:51 AM
  3. M1-ATX and heavy 12V rail
    By miki in forum Power Supplies
    Last Post: 05-13-2005, 07:18 AM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  5. Possible Solution for Dual Sproggy 12V @ 10A
    By mp3z24 in forum Power Supplies
    Last Post: 07-10-2003, 12:33 PM
