Ok, i dl'ed what appears to be the latest app on your list (2.2.1 me thinks) and the AI voltage is reported exactly the same, that is < 2.5V shows fine but >2.5V still goes to 2.5V max (2.49V something or 511[int] TBE). This is not a
software issue at least not outside of the either FusionUSB.dll or the mpusbapi.dll libraries depending which USB driver's loaded. Your app gets the same bytes I do. The odd-byte never gets the 128 bit set HI no matter the voltage applied except when you put >~4V it flashes full 1023 on every now and again and mostly reports close to zero. We tried just about anything, went over the board, ensured proper contacts, grounding etc all seems well, + like I said, < 2.5V is measured accurately albeit with occasional 5-10% fluctuation above ~2V. Something is definitely not right or I am seriously missing something.
