Results 1 to 7 of 7
Thread: conflicting posts on anti-thump hookup
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I've a read a few posts with conflicting information on how to hook up anti-thump to the fusion brain. Once post suggested i can just hook my 3sixty's accessory line directly to a digital out line on the fb. Another post said a relay was mandatory to accomplish this. Which is correct?
    And while i'm at it i have another question. My 3sixty is hooked up to the pre-existing radio wires for power/acc. When i turn off the car i get a pop from the speakers because the 3sixty turns off before the computer does. Would hooking the accessory line from the fusion brain to the 3sixty effectively solve both issues?
    Live mp3Car Facebook Chat
    Fusion Brain Creator
    Mar 2005
    It depends on the device you're turning on. Do you have a link to the "3sixty"?
    And yes, with the timer on the FB, you can delay the turnoff.
    Woodbridge, VA
    Blog Entries
    55
    http://www.rockfordfosgate.com/produ...S&series_id=49 this is what basically controls the sound output of my whole system.
    Mar 2006
    Colorado, but Canadian!
    If it is positive switched you need a relay.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    which it is, so you need a relay.
    Woodbridge, VA
    Blog Entries
    55
    looks like i'll be making another order soon full of relays and extensions then lol
    Mar 2005
    sounds good. all orders without a fusion brain should be shipped within 1-2 business days.
  1. Using advanced search to read the last 'X' posts
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 03-06-2005, 06:38 PM
