Results 1 to 10 of 14
Thread: Few pics of my fusion brain board
    Jan 2008
    Southern Calif
    Aug 2006
    Central PA
    Holy crap! What do you have this thing doing? You obviously have alot of information to share .
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    um fusion what? That looks like the telephone closet in the mall i work in lol
    Live mp3Car Facebook Chat
    Jan 2008
    Texas
    looks good, here's mine so far, I used an old power inverter to house it. i removed the 110v plugs and replaced them with relay sockets and stuck a db-25 connector above the relays to run my wiring through, it will give me enough connections for now and I can add another one later when I need it.
    Mar 2006
    Colorado, but Canadian!
    Both are really nice!
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2008
    Southern Calif
    Looks good, what u using the db-25 connector for? What kind of project is it?
    Mar 2005
    wow, impressive.
    Jan 2008
    Texas
    Quote Originally Posted by rgarjr View Post
    it is for my car but I wanted a way to connect it that was easy to disconnect if I needed to bring it in. I figure the db-25 will handle any thing going through it, any other relays I use will be automotive relays and I can hide them where ever they are needed. I had thought about using a 40 pin ECM connector but that meant scrounging through salvage yards and the db-25's are cheap and easy to find, plus I have boxes of old serial cables laying around to cut up and make pigtails from. next I will build a relay board and bread board with a db-25 to connect to it on the bench for mock-ups
    This should leave 5 open pins on each DB-25 some of which will be used for the 2 internal relay's
    Woodbridge, VA
    Blog Entries
    55
    thats a really creative idea. I'm goin to radio shack today to find a regular old project box to hack up.
    Mar 2005
    DB25s are only good for like 2 amps per pin, be careful
  1. power fusion brain from car battery
    By customaudioman in forum Fusion Brain
    Last Post: 03-14-2008, 07:41 PM
  2. Fusion brain with 3000GT Steering Wheel Controls
    By TerraWombat in forum Fusion Brain
    Last Post: 02-22-2008, 01:27 AM
  3. Fusion brain data questions
    By AtomicMonkey in forum Fusion Brain
    Last Post: 02-19-2008, 03:12 PM
  4. Custom Firmware for Fusion Brain
    By fermentation in forum Fusion Brain
    Last Post: 02-11-2008, 11:34 AM
  5. Replies: 25
    Last Post: 11-13-2006, 03:35 AM
