Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 40 of 103
Thread: Steering Wheel Control Help
  1. #31
    Aug 2005
    If I setup logging does it accept path or just dump the log file in the root?
  2. #32
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by SKiTLz View Post
    The "Log File Name" in the configurator is the path. If it is just a name, then it is in the root. If it is "/blah/X" then it will be saved in root/blah/X.xml
    If the path is "C:/blah/y" then it will save it in C:/blah/y.xml
    1.9in x 2.9in -- 47mm x 73mm
  3. #33
    Aug 2005
    greenman100. Just looking at my service manual again. Wouldn't pin 17 be the ground not 20?
  4. #34
    Mar 2005
    yup, sorry
  5. #35
    Aug 2005
    Cool. Thanks.
    Just because I'm a picky sob and like diagrams I made a pretty one.. Figured I'd post it incase anyone was ever searching and came across the thread.
  6. #36
    Mar 2005
    that is correct!
    also don't connect those pins to anything else at teh same time, like your factory system
  7. #37
    Aug 2005
    Quote Originally Posted by greenman100 View Post
    that is correct!
    Looks like where all good to go with the wiring.. Need to get it in to test the software side..
    Appreciate the help
  8. #38
    Aug 2005
    To revive this thread. Got the brain in the car today. Tried to get it all working..
    First of all I'm back to the software crashing like crazy on my Laptop. Can't get it to run. Yes im using the latest version etc. Did everything I did on my desktop.
    So i try the carpc. Made sure all the prereques where on. NET 2.0 etc. Won't even run. No error. No crash. Just doesn't run.
    Software aside though..
    When i push any of the steering wheel buttons should the green lights on the Brain not light up? Cause im getting nothing.
  9. #39
    Mar 2005
    The green lights are indicative of the output states, not the inputs... so no, they will never light.
  10. #40
    Aug 2005
    I just ripped it all out and tested reistance.. Everything is spot on.. Seeing 5V on the line. Voltage is varying with button presses.. Everything is correct..
    So looks like its just this POS software. Sorry guys but wow this software is flaky.. I've got 3 diffferent laptops with me and it crashes on all.
    EDIT: How do i get debug mode so i know why this thing is crashing? adding -debug to the path does nothing.
  1. Steering Wheel Remote Control
    By drdave in forum Car Audio
    Last Post: 02-21-2008, 10:48 PM
  2. Audy A8 Steering Wheel Control to PC
    By k11SiC6 in forum Input Devices
    Last Post: 03-02-2007, 04:54 PM
  3. Steering wheel control and durability
    By bimmerpc in forum General Hardware Discussion
    Last Post: 11-01-2005, 02:01 PM
  4. Steering Wheel Control
    By Micv in forum Hardware Development
    Last Post: 07-13-2005, 11:45 AM
  5. Using steering wheel controls to control mini mac?
    By brandondente in forum MacCar
    Last Post: 05-12-2005, 09:50 AM
