Code:
<?xml version="1.0" encoding="utf-8" ?>
<FusionControlCentreConfiguration version="3.0.0.0" author="Jayson" date_created="April 11, 2008 at 2:32:35 PM" last_modified="April 11, 2008 at 3:51:29 PM">
<require>
<!-- Begin Function Instances -->
<!-- End Function Instances -->
</require>
<graphics>
<!-- Begin Global Graphic Settings -->
<main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="True" MinimizeToSystemTray="True"></main_display>
<!-- End Global Graphic Settings -->
<!-- Begin Background Images -->
<!-- End Background Images -->
<!-- Begin Static Images -->
<!-- End Static Images -->
<!-- Begin Display Buttons -->
<!-- End Display Buttons -->
<!-- Begin Multi Images -->
</graphics>
<io>
<!-- Begin Fusion Brain Instances -->
<brain id="fb1">USB\VID_04D8&PID_000c\5&376e92c4&0&1</brain>
<!-- End Fusion Brain Instances -->
<!-- Begin Timer Setup -->
<timer id="input" interval="75"></timer>
<timer id="output" interval="100"></timer>
<timer id="gui" interval="50"></timer>
<timer id="logic" interval="50"></timer>
<!-- End Timer Setup -->
<!-- Begin Digital Output Instances -->
<!-- End Digital Output Instances -->
<!-- Begin Analogue Input Instances -->
<iochannel id="steering0" port="0" brain="fb1" type="analogue_input">
<options history="0" auto_average="true"></options>
</iochannel>
<iochannel id="steering1" port="1" brain="fb1" type="analogue_input">
</iochannel>
<!-- End Analogue Input Instances -->
</io>
<logic>
<!-- Begin Logging Setup -->
<all_logging>
<log LogID="log steering0" MonitorType="Analogue Input" TargetID="steering0" fire_on="input">
<options DefaultMonitorState="On" filename="Logs\Steering0" StoreBeforeDumping="100" holdStreamOpen="False"></options>
<data DataName="Steering0" DataFrom="Value"></data>
</log>
<log LogID="log steering1" MonitorType="analogue input" TargetID="steering1" fire_on="input">
<options DefaultMonitorState="On" filename="Logs\Steering1" StoreBeforeDumping="100" holdStreamOpen="False"></options>
<data DataName="Steering1" DataFrom="value"></data>
</log>
</all_logging>
<!-- End Logging Setup -->
<!-- Begin Variable Declarations -->
<all_variables>
</all_variables>
<!-- End Variable Declarations -->
<!-- Begin Logic Declarations -->
<all_statements>
</all_statements>
<!-- End Logic Declarations -->
</logic>
</FusionControlCentreConfiguration>
