Ok here is what I've been trying. Not sure I have the format for title:class correct for the Window.
Voltage is broad just for testing.
Code:
<?xml version="1.0" encoding="utf-8" ?>
<FusionControlCentreConfiguration version="3.0.0.0" author="Jayson" date_created="April 11, 2008 at 2:32:35 PM" last_modified="April 11, 2008 at 3:51:29 PM">
<require>
<!-- Begin Function Instances -->
<!-- End Function Instances -->
</require>
<graphics>
<!-- Begin Global Graphic Settings -->
<main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="True" MinimizeToSystemTray="True"></main_display>
<!-- End Global Graphic Settings -->
<!-- Begin Background Images -->
<!-- End Background Images -->
<!-- Begin Static Images -->
<!-- End Static Images -->
<!-- Begin Display Buttons -->
<!-- End Display Buttons -->
<!-- Begin Multi Images -->
</graphics>
<io>
<!-- Begin Fusion Brain Instances -->
<brain id="MainBrain">USB\VID_04D8&PID_000C\5&300B12AB&0&2</brain>
<!-- End Fusion Brain Instances -->
<!-- Begin Timer Setup -->
<timer id="logic" interval="65"></timer>
<timer id="gui" interval="30"></timer>
<timer id="output" interval="100"></timer>
<timer id="input" interval="50"></timer>
<!-- End Timer Setup -->
<!-- Begin Analogue Input Instances -->
<iochannel id="SteeringWheel_Sence" port="0" brain="MainBrain" type="analogue_input">
<options history="100" auto_average="false"></options>
</iochannel>
<!-- End Analogue Input Instances -->
</io>
<logic>
<!-- Begin Logging Setup -->
<all_logging>
</all_logging>
<!-- End Logging Setup -->
<!-- Begin Variable Declarations -->
<all_variables>
</all_variables>
<!-- End Variable Declarations -->
<!-- Begin Logic Declarations -->
<all_statements>
<!-- ** Button UP ** -->
<if fire_on="logic">
<parameter1>
<if>
<parameter1>
<analogue id="SteeringWheel_Sence" time="0"></analogue>
</parameter1>
<test check="greater than or equal to"></test>
<parameter2>
<number>0.1</number>
</parameter2>
</if>
</parameter1>
<test check="AND"></test>
<parameter2>
<if>
<parameter1>
</parameter1>
<test check="less than or equal to"></test>
<parameter2>
<number>4.9</number>
</parameter2>
</if>
</parameter2>
<then>
<do function="send key" functionTargetID="centrafuse:WindowsForms10.Window.8.app.0.378734a" vote_opinion="M" vote_priority="medium"></do>
</then>
</if>
<!-- ** Button DOWN ** -->
<parameter1>
<if>
<parameter1>
</parameter1>
<parameter2>
<number>.6</number>
</parameter2>
</if>
</parameter1>
<parameter2>
<if>
<parameter1>
</parameter1>
<parameter2>
<number>2.9</number>
</parameter2>
</if>
</parameter2>
<then>
<do function="send key" functionTargetID="centrafuse" vote_opinion="CTRL::B" vote_priority="medium"></do>
</then>
</if>
<!-- ** Button MODE ** -->
<parameter1>
<if>
<parameter1>
</parameter1>
<parameter2>
<number>3.0</number>
</parameter2>
</if>
</parameter1>
<parameter2>
<if>
<parameter1>
</parameter1>
<parameter2>
<number>3.5</number>
</parameter2>
</if>
</parameter2>
<then>
<do function="send key" functionTargetID="centrafuse" vote_opinion="F8" vote_priority="medium"></do>
</then>
</if>
<!-- ** Button VOLUME UP ** -->
<parameter1>
<if>
<parameter1>
</parameter1>
<parameter2>
<number>3.6</number>
</parameter2>
</if>
</parameter1>
<parameter2>
<if>
<parameter1>
</parameter1>
<parameter2>
<number>4.2</number>
</parameter2>
</if>
</parameter2>
<then>
<do function="send key" functionTargetID="centrafuse" vote_opinion="F10" vote_priority="medium"></do>
</then>
</if>
<!-- ** Button VOLUME DOWN ** -->
<parameter1>
<if>
<parameter1>
</parameter1>
<parameter2>
<number>4.3</number>
</parameter2>
</if>
</parameter1>
<parameter2>
<if>
<parameter1>
</parameter1>
<parameter2>
<number>4.6</number>
</parameter2>
</if>
</parameter2>
<then>
<do function="send key" functionTargetID="centrafuse" vote_opinion="F9" vote_priority="medium"></do>
</then>
</if>
</all_statements>
<!-- End Logic Declarations -->
</logic>
</FusionControlCentreConfiguration>
