What were you measuring? Pin 16 to ground? and Pin 20 to ground?
I'm a little confused on hooking up my steering wheel controls.
Car is a 2006 350z.
Steering wheel controls are 2-Wire Resistive type.
Pin 16
Power (Press and hold POWER switch.) Approx. 0Ω
Seek down (Press and hold SEEK DOWN switch.) Approx. 165Ω
Volume down (Press and hold VOLUME DOWN switch.) Approx. 652Ω
Pin 20
Mode Press and hold MODE switch. Approx. 0Ω
Seek up (Press and hold SEEK UP switch.) Approx. 165Ω
Volume up (Press and hold VOLUME UP switch.) Approx. 652Ω
How should I hook this up? Please in laymen terms.![]()
Straight from the service manual.. Thanks mate
Nice! I can help but I'm not home right now. I will in the next day or two, rest assured.
you'll need two resistors, that's it. I'll post info later
read this:
http://www.mp3car.com/vbulletin/docu...-controls.html
apply solution D twice
Thanks. I have read that thread but I don't get the wording.
So one steering wheel wire goes the Fusion Brain ground (does it matter which?)And your steering wheel is R2. Connect one steering wheel wire to ground, and the other the steering wheel wire to the input of the brain and one side of R2. Connect the other side of R2 to the +5vDC pin on the brain's analog input header (towards the center of the board). You're done!
Then the other goes to the brain analog input and R2? I'm connecting one wire to two places?
Look at your service manual. Pin 17 is shared by the two steering wheel controls... is it has to be ground.
Pin 17 to ground
Pin 16 to FB input and R1
Pin 20 to FB input and another R1
tie the other sides of both R1s to +5vDC on the FB.
make sense?
I just fixed the wording in that other thread.
i'll whip up a drawing, h/o
