Results 1 to 10 of 10
Thread: Triggering multiple outputs with 1 image
    Jan 2008
    Southern Calif
    Can you program the FB to trigger ON multiple outputs when you click one image?
    What would the code look like for output? Here's the code for one image.
    #STARTNEW#
    #NAME#FRONT UP
    #TYPE#RELAY
    #VIDPID#MyBrain
    #DEFAULTSTATE#false
    #DEFAULTENABLESTATE#true
    #SIZE#70,45
    #LOCATION#364,194
    #AUDIOFROMOFFTOON#
    #AUDIOFROMONTOOFF#
    #SHOWTEXT#false
    #PAGE#0
    #TIMER#0
    #PORT#99
    #TXTCOLOURON#Black
    #TXTCOLOUROFF#Black
    #BORDERSIZE#0
    #FONT#Arial;12;Regular
    #ENDNEW#
    I'm trying to simulate the switchbox, the top middle switch controls the 2 fronts, middle left switch controls left side, etc.
    Mar 2006
    Colorado, but Canadian!
    In version 2 you use the LINK command.
    However, I suggest you use MDX where you would have the button change a variable, and then the logic is where you can trigger as many outputs as you want or do whatever else you want.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2008
    Southern Calif
    2k1,
    How would that LINK line be if I want to trigger port 1 and port 2?
    I can't really use the skin designer because you can't go back in there and change stuff once you save the skin. Or can u? I need to manually change the code in notepad.
    Mar 2006
    Quote Originally Posted by rgarjr View Post
    2k1,
    If you are using version 2, then you need to create a new digital output, and the order the output is in the skin file is what you put in the link.
    So if the first output is the one above, then the 2nd output is what you want to link then the LINK field of the first is "#LINK#1
    And yes the configurator opens things for MDX. And you can always use a text editor instead or now Dreamweaver or anything.
    You are welcome to use either, but once I finish MDX's config program, version 2 will be taken down from the site, and support will stop for version 2. I have been telling people to use MDX since November, and it will be final within the month I hope.
    Jan 2008
    Southern Calif
    So you're saying to create variables, then create a logic?
    Mar 2006
    yes. Make a variable for the button you want.
    Make the button, and in its vote section (bottom left of the config) have it change the variable you made by something like +1.
    Then when you click the button it will go 0,1,2,3,4,...
    Now in the logic section put if variable is 1 then do this and do this and do this and do this where this is anything including turning on outputs. Then the next logic section should be if variable is greater than or equal to 1, set variable to 0.
    Make sense?
    Jan 2008
    Southern Calif
    Well it does sound a bit confusing... I'm sure its not.
    Mar 2006
    It is pretty easy in the configurator.
    Jan 2008
    Southern Calif
    I'm sure its easy once you know what you're doing, but for someone that hasn't.. could be hard. I've played around with the logic page, adding and gates and things... how do u join them together (wire)
    Mar 2006
    Right click the node (the little ring thing).
  1. Software to make a bootable backup image and send that over network to burn
    By nobb in forum Software & Software Development
    Last Post: 04-14-2007, 07:49 PM
  2. User Image Hosting
    By RedGTiVR6 in forum Mp3car Forum Suggestions/Comments
    Last Post: 03-14-2007, 08:30 AM
  3. Free image hosting - No Bandwidth limitation.
    By lifemalfunction in forum Off Topic
    Last Post: 02-23-2007, 04:28 AM
  4. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 04:02 AM
  5. Multiple Sound Outputs
    By djXternal in forum Car Audio
    Last Post: 10-04-2004, 03:58 PM
