For a single Sensor.
Great hardware/software solution guys. Also looking forward to the Com integration for RoadRunner.
Kinda like this:
72.125 F
26 C
or
72.125 F/26C
Sound StageEclipse|MTX|Infinity
1.9in x 2.9in -- 47mm x 73mm
So you were saying the first is doable, how do I put two variables in a single Label from a single sensor? just duplicate the #SETTINGS# in the same #STARTNEW# But with different variables?
Here is a nice screenshot of my Brain and temps working fine in RoadRunner btw. Will install in the car on the weekend, all seems working, all systems GO.
are you just skinning our software inside RR?
Also: I think Nick's advice was foer MDX, not Ver 2.0
Yep skinning until the dll is available that supports COM, this is a good interum solution. MDX maybe an issue for those of us with Intel "Little Valley" boards as they only support direct x 7. But going to try and install Direct x 9c had hope it simply does not take advantage of the more complex graphic features.
So is there a way to show both C and F for one variable and one sensor under the old ver. 2 software?
Thanks! Panda, err bear, errr raccoon, err furry thing.
