Sorry I saw this, but I forgot to answer.
Basically create a variable and set it to 0. Have a logic saying, varaible = variable + 1. Then another logic saying if variable is greater than x where x is the number of frames you want, then variable = 0. This will make the variable go 0,1,2,3,4,...x,0,1,2,...
Then make 1 logic for each number from 0 to x [n], and say if variable equals n, and attach to an output. In this logic's do then statement, add what you want to happen like trigger digital outputs or something.
Also we do custom skinning for $20/hr, but this is not possible at the moment as both Tim and I are very busy. If it is an emergency we can work something out.
1.9in x 2.9in -- 47mm x 73mm
