Page 3 of 10 FirstFirst 12345678910 LastLast
Results 21 to 30 of 92
Thread: Fusion Brain Reloaded
  1. #21
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Quote Originally Posted by Arrow View Post
    Will the new board work along side the old board, in the same skin?
    Never mind, I thought about that immediately after I posted it. The brain is controlled by the software. So, the ability to use both with be a software limitation, which I think toaster will have no problem implementing.
  2. #22
    Mar 2006
    Colorado, but Canadian!
    correct.
    They will be exactly the same in software. You will be able to have a mixmatch of either versions along side eachother no problem. There is never an either/or, always a both.
    1.9in x 2.9in -- 47mm x 73mm
  3. #23
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    What about analog and digital inputs that work off a 12v signal?
  4. #24
    Mar 2006
    Quote Originally Posted by bratnetwork View Post
    just divide the signal, and send it in.
  5. #25
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by 2k1Toaster View Post
    what do u mean?
  6. #26
    Mar 2006
  7. #27
    Oct 2006
    Las Vegas
    Yay for the bus port!!!
    Bigger memory? Will this be the version that could have some extra programming squeezed into it? how much "user accessible EEPROM" will there be?
    will analog out work it's way into this one (perhaps via I2C)?
    I'm drawing blanks for a name.
    And for the big question...
    When Can we PRE-order?
  8. #28
    Mar 2005
    Quote Originally Posted by h3rk View Post
    We will put EEPROM either on the brain itself, or as an I2C module. We're thinking 64 kilobytes should be plenty. This would allow for 32,000 analog input samples.
    yes, there will be analog out.
  9. #29
    Slovenia (EU)
    Would the inputs work too when PC is off?
    What I mean is: if you use FB for HVAC, and PC dies... is there a way to have some buttons hidden and attached to FB and an LCD. Could you still control FB and your HVAC?
  10. #30
    Mar 2005
    Quote Originally Posted by stric View Post
    possibly, in the future
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. New Fusion Brain, other hardware
    By greenman100 in forum Fusion Brain
    Last Post: 02-17-2008, 09:15 PM
  4. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
  5. Fusion Brain Integration
    By michael2 in forum RR Plugins
    Last Post: 08-22-2007, 12:59 AM
