Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 92
Thread: Fusion Brain Reloaded
  1. #51
    Vendor - Qube colin's Avatar
    Dec 2006
    Wow, it's so ... beautiful.
    7cm x 4cm eh, reminds me of a MiniPac haha
  2. #52
    Jul 2005
    look so good man! im going to in for a new one before even installing my first one lol
  3. #53
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    The new layout looks nice. The feature requests I have are more firmware related. Here are my ideas:
    If the board is disconnected from the computer (doesn't receive an update after some time), can all digital outputs revert to their default state of off.
    If the PIC crashes (due to bad power), can a watchdog be put in place to reboot the PIC?
    Is there any possibility of doing a PWM output on some or all of the digital outputs?
  4. #54
    Dec 2007
    I have a hardware request. Is there a way we can get 12volts out on the outputs? If you are still using ULN2003's it would be easy. You could even put a jumper in and select 5 or 12 volts.
  5. #55
    Dec 2006
    ULN2003's eh?
    It seems that the setup you guys use is very similar to mine!
    I created a board that uses a PIC18F4455 and 2x ULN2003 for the outputs.
    Then there's a few analog and digital inputs that have no circuitry between them.
    Good stuff, I know I did something right now
  6. #56
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by RonS View Post
    the outputs have always used 12 volts, and will continue to do so....
  7. #57
    Dec 2007
    Oh Ok. For some reason I was thinking that they were 5 volt. I guess I should have measured them. Sorry about that.
  8. #58
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    just a suggestion, i see you have a label on the board now for the analogue inputs,
    is there a pin one ID somewhere? and is pin 1 the +5v or the input +
    something more like this perhaps?
    the sensors supplied with the FB have the red (+5v) as pin 1, and putting them in backwards (towards what is labelled on the current FB pin 1) makes them go a bit hot
  9. #59
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Woofnstuff View Post
    Notice the +, -, AN... That is what they are there for. You actually put your text over it.
    And it is also in the hardware manual which is which for the current version. Red on the sensors is and has always been +. Connecting backwards not only makes the sensor hot, but can destroy your sensor.
    1.9in x 2.9in -- 47mm x 73mm
  10. #60
    Oct 2007
    Auckland
    i know i put my text over it...
    was suggesting more descriptive labels thats all
    that would wire it backwards on the above yes?
    make it more dummy proof...
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. New Fusion Brain, other hardware
    By greenman100 in forum Fusion Brain
    Last Post: 02-17-2008, 09:15 PM
  4. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
  5. Fusion Brain Integration
    By michael2 in forum RR Plugins
    Last Post: 08-22-2007, 12:59 AM
