Page 9 of 10 FirstFirst 12345678910 LastLast
Results 81 to 90 of 92
Thread: Fusion Brain Reloaded
  1. #81
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by NitroLarry View Post
    Hey Tim,
    So how long before the firmware is up and running for I2C? For me I really want to utilize the bus.
    What for?
  2. #82
    Dec 2006
    Quote Originally Posted by greenman100 View Post
    What for?
    Right now I'm working with the Microchip PICkit Serial Analyzer and the MCP4725 EV Board for analog voltage out. I'm still new at this stuff, but it seemed to me using I2C could simplify producing adjustable analog voltages with the proper DAC device. In the end I hoped to use the FB as a master to incorporate it into a CarPC and control HVAC functions.
    Honestly, with my limited knowledge on this stuff, I may be going down the wrong path, but I guess you could say live and learn.
  3. #83
    Mar 2005
    If you're just controlling motors, such as the fan motor, PWM is much better (more efficient), and is already a feature on Version 4.
  4. #84
    Dec 2006
    My goal would be to just mimic HVAC controls, so just replacing the input of the rotary pot to the HVAC control head with the adjustable voltage from the FB over I2C using a DAC. I agree PWM for the fan and door motors the way to go. I was trying to avoid using up all (or most of) the FB outputs creating an array of resistors just to achieve specific voltage outputs.
    I don't want to hi jack this thread on the introduction of the new Fusion Brain, but if I'm making sense on what I'm trying to achieve here and/or you have a better solution please feel free to PM. The more I can learn the better.
  5. #85
    Mar 2005
    You could do PWM and a low pass filter, would work particularly well if you used an analog input for feedback.
    I2C is a few months off, and will probably be limited to chips we test with... but Version 4 will support it.
  6. #86
    May 2008
    Quote Originally Posted by 2k1Toaster View Post
    IT'S ALIVE!!!
    Up for sale now!
    Fusion Brain
    USB I/O Board with 12 Digital Outputs, 10 Analogue Inputs, 4 Digital Inputs and only 68mm x 68mm!
    Now Shipping Worldwide!!!
    You might want to update your .sig then...
    Edit:
    From the product page:
    Sensors can be connected to any one of the 10 analogue inputs for readings varying from Temperature to Distance to the amount of Light present.
    Relays or LEDs can be connected directly to any of the board's 12 digital outputs header pins allowing for easy installation.
    Shouldn't that be 13 and 16 respectively?
  7. #87
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Sicarius View Post
    Good point...
    1.9in x 2.9in -- 47mm x 73mm
  8. #88
    Feb 2006
    Are you guys using the PIC18F4550 or 4553?
    THX!!
  9. #89
    Mar 2005
    Quote Originally Posted by hartigan View Post
    THX!!
    4550, why?
  10. #90
    Mar 2005
    Edit:
    fixed, thanks!
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. New Fusion Brain, other hardware
    By greenman100 in forum Fusion Brain
    Last Post: 02-17-2008, 09:15 PM
  4. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
  5. Fusion Brain Integration
    By michael2 in forum RR Plugins
    Last Post: 08-22-2007, 12:59 AM
