and a couple easy answers:
You can cut the wire in half. However, if it's not properly shielded, you run a risk of picking up noise.... so basically, YMMV.
White stripe wire is positive. Even if you hook it up backwards, nothing should blow up... the power regulator will get real hot and the power LED won't light.
LinkBack URL
About LinkBacks
