Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: My FB project, Question on MOSFETs
  1. #11
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    H3rk, I built the software from the ground up.
    Bes, I have been thinking about getting a couple of those to test. The load is a coil on a hydraulic valve, and it was creating a voltage drop/spike that the FB didn't like. Moved the FB to a different power source, and it has behaved normally ever since. I'm also seeing some odd behavior from my GPS antenna, which I suspect is also being caused from the voltage drops/spikes. I'm going to change where they are powered from to isolate that spike, which means a mosfet won't work for me any more. For right now, I like the sound of the relays to know what they are doing, but ultimately I need something more resilient, and a solid state relay looks to be a good option.
    -Lance
  2. #12
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by bes51659 View Post
    Fastest way to goal is to buy solid state relays. And maybe safest...
    Quick search: http://www.ab.com/industrialcontrols...ate_relay.html
    Solid state relays have issues, they can easily send signals back up the wrong way causing more headache of problems. Solid states are good for HDD, but when it comes to solid state switches, i would stay away. If you google the issues Solid State Relays have you would get a whole list of issues.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #13
    Newbie sandmanx5's Avatar
    Feb 2008
    Edmonton, AB
    If you go with solid state - look for ones that are built using opto-isolators or just look at using an opto-isolator directly...
    http://en.wikipedia.org/wiki/Opto-isolator
    and
    http://homepages.which.net/~paul.hil...rol/Optos.html
    These are likely the solution I'll be using in my setup.. Absolutely no chance of power leaking across the gate as there is no physical connection for it to happen to.
    Brilliant idea for running a tractor BTW.. I should show your idea to my aunt.. Maybe she'll let me pimp out her tractor too!
    Jason
    '02 Mazda Protege5
    '92 Jetta IDI
    No carputer yet - but its in the planning!
  4. #14
    Jan 2008
    Texas
    Quote Originally Posted by h3rk View Post
    What a scary thought.. At least this is way out in the open.
    "SCARY" you obviously haven't driven through Houston lately! I think I'd prefer to know a computer was in charge of things than some of the idiots around here!
  5. #15
    Jun 2006
    Chicago, IL
    WOW1 Man!
    I work for a company that makes all kinds of relays.... I'm going to spread the word how these are used....
    Solid state relays will do the job, these can handle up to 125 Amps...
    EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
    Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
  6. #16
    Aug 2003
    Iowa
    Here are a couple videos of the system in action. The first video is what it looks like in the cab, the second video shows the blinky lights on the FB.
    http://www.youtube.com/watch?v=YFqfTlqF2NY
    http://www.youtube.com/watch?v=YBoFKmAFVfc
    Since I originally posted, I have added a yaw sensor to the system, which makes the steering much smoother. The only time I feel it make a steering adjustment is when I go through some rough ground. Even then, it is only a 3-6" steering move. I have gotten the line-holding ability down to staying within 6" of the line, and I'm still working on making the even smaller. My goal is 2-3".
    And since you guys brought it up, I am told that there are city buses in Minneapolis that are being driven by GPS. The driver brings the bus to the curb, and puts it back in the traffic lane, but then the computer takes over and steers the bus along the route. The driver still has control of the throttle/brakes, and of course can manually steer to avoid a collision or whatever.
    -Lance
  1. PROJECT ST34LTH : Project Car Purchased w/PICS
    By ST34LTH in forum General Hardware Discussion
    Last Post: 09-01-2008, 10:09 AM
  2. Complete Newbie Question.
    By DomesticImport in forum Newbie
    Last Post: 07-07-2005, 07:24 PM
  3. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
  4. Project "Ford Windstar XP"
    By Vchat20 in forum Show off your project
    Last Post: 02-14-2005, 04:47 AM
  5. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
