closing the software should turn off the output. what version are you using?
Copying from a private thread:
So, what I'm wishing to do is get the FB software to switch the amps off before I go into standby and then auto switch them on after standby. I haven't tried fiddling with HibernateTrigger yet, but that may work out. The FB unit should switch the relay off if the software is turned off? I'm not sure mine is doing that. I'll have to test some more.Quote: Originally Posted by HyperZulu
I am setting up my FB for the first time and I notice that after setting it up, it seems to wait for the software to load up before first turning on the relay I set for anti-thump on the amp remote wires, but when I exit the program or simply go into standby I notice the relay is still hot, so I get the thump on the standby going down and then coming back up. I can switch the relay off while the program is on and I manually switch it, but that's not the normal behavior I presume. Should I be doing something special to get the relay to switch off before standby?
From green: Copy/paste this PM into a post in the open forum, and we'll add functionality to the program!
I was going to wire my FB to the psu's 12v line, but opted not to since I don't know which line would die first, the 12v line to the amps (thump) or the FB (no thump)...
Thanks.
Pretty sure I have 2.2.1 running. I'm going to run and check that I'm not a liar right now.
2.2.1 should turn off the outputs. are you using the timer tag?
Set the timer to 0.
You're basically setting the brain to stay on for like a day
Wasn't in the manualIt was set to 30 in the tutorials section. Is there a document outlining different properties and what their values can be set to, what they mean, etc?
What should I set TIMER to in my case?... 0, 1? Not sure how this variable increments. I guess I'll experiment.
woops, i mean set the timer to 0. sorry
Set timer on that port to 0 and I am still having the same response. I've tried older versions of the software with the same issue. Not really sure if this is hardware or software. On one hand it seems like software... but I don't know how the unit is programmed on the PIC. Is it set to look for the *.exe and if missing, turn off all ports? Or are all ports supposed to be switched off when the program shuts down? In any case, the brain leaves the port(s) on. I say ports since I tried other ports and they all behave the same way.
The software should shut everything down on exit, wait for 2k1's response on that.
are you sure you're actually closing the software (check task manager)
what happens when you unplug the unit, with all timers set to 0?
