Results 1 to 10 of 11
Thread: 2 wire sensors
    Jan 2008
    Texas
    2 wire sensors
    This is a stupid question that I should know the answer to but bear with me as I have spent as many years trying to forget this stuff since retiring than I spent learning it. In an automotive application you typically have 2 wire and 3 wire sensors, 2 wire sensors like thermistors for measuring temperatures are common. your temp sensor is a 3 wire sensor which makes it easy to hook up to a board that is set up for 3 wire analog inputs, but just the same, a 2 wire temp sensor is an analog input also.
    Now if I wanted to utilize my already present ECT sensor can I just use the 5vdc and sensor return, disregarding the GND, or do I need to build some other circuit to interface it?
    Fusion Brain Creator
    Mar 2005
    http://www.mp3car.com/vbulletin/docu...uspension.html
    the fusion brain senses voltage, 2 wire sensors are variable resistance so they must be wired as part of a voltage divider
    Jan 2008
    Texas
    So looking at the schematic you provided in the link then my 2 wire resistive sensor would go between the GND and the Input terminals on the brain and the 5vdc terminal would connect to a resistor of which the other end would tie in with the input terminal right?
    also is the value of R1 a constant or is this going to be something that depends on the resistive range of the thermistor and if so is there a formula to determine the proper value?
    Mar 2005
    "also is the value of R1 a constant or is this going to be something that depends on the resistive range of the thermistor and if so is there a formula to determine the proper value?"
    the latter, and you can certainly optimize, but a nice rule of thumb is R1 = highest resistance the sensor can be
    Jan 2008
    Texas
    So if I have a thermistor that reads roughly 13k at ambient temp and 60k at freezing, I should be able to replace R1 with a 100k pot and adjust that to get the most accurate temp readings across the range I will be using and then replace it with a resistor valued approximately at the resistance I find with the pot?
    Mar 2005
    yup, that'd work
    Jan 2008
    Texas
    just one other problem, what if my thermistor is a negative temperature coefficient device?
    Mar 2005
    why is that a problem?
    Jan 2008
    Texas
    because as the temperature rises the voltage goes down. with room temp I show about 60 degree F, if I stick the thermistor in ice water It jumps to 125!
    Mar 2005
    Quote Originally Posted by jimp View Post
    how are you converting to temperature?
    it's not a problem, you just need a new formula to convert to temperature, utilizing the negative coefficient
  1. Question for Zootjeff, What's the DSATX white wire for?
    By greatwhite in forum Power Supplies
    Last Post: 10-21-2007, 01:18 PM
  2. Opus ignores ignition wire, constantly stays on
    By Sham-Mobile in forum Power Supplies
    Last Post: 08-26-2006, 07:28 PM
  3. Question about wire to connect to battery
    By thanassius in forum Power Supplies
    Last Post: 08-07-2006, 11:35 AM
  4. Totally dissapointed with my carputer!
    By Maheriano in forum General MP3Car Discussion
    Last Post: 07-16-2006, 09:26 PM
  5. Pseudo-FAQ: What Do I Need For A Carputer?
    Last Post: 07-03-2006, 03:04 PM
