Results 1 to 10 of 12
Thread: fusion brain and vista x64
    Mar 2008
    i have a problem with the FusionUSB.dll in vista 64bit, i belive its the dll file, the drivers for FB is correct installed, but the mdx app cant find my FB (installed the installer version), and a the demoFB is saying it cant find the FusionUSB.dll and i'm geting the same error in my coded project as the FBdemo app.
    "An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)"
    FusionUSB.dll are not working in Vista x64? Or can it be something else?
    anyone tested the fusion in vista 64bit version?
    Fusion Brain Creator
    Mar 2005
    We have not tested it in Vista x64, I know that much.
    Nick may be able to shed more light on the subject.
    Mar 2006
    Colorado, but Canadian!
    I have never tried any x64 OSs with the Fusion Brain.
    It could be the FusionDLL, but it doesnt actually do much, it just interfaces with winusb.
    You can try to use the x64 copy of WinUSB.dll and directly interface with it for your program. I have only 1 computer that has x64 XP on it, and it works fine. I have no x64 copy of Vista.
    Is there a "XP compatibility mode" available when you go to the file property? I never really tried with Vista.
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2005
    Australia
    I know this thread is a bit old now pskogly, but did you manage to get the fusionbrain tester working with vista x64? I can the program to load and the ID to come up but cant communicate.
    Mar 2008
    yepp, same problem i got..
    Mar 2006
    Direct from the website:
    Requires: Microsoft® Windows® XP Pro or Home with Service Pack 2 or Windows Vista™ Home Premium, Business, Ultimate, or Enterprise (certified for 32-bit editions)
    This is not high on the list to change, but I have a plan to hopefully get this to work in the future on x64 systems.
    Mar 2006
    Does someone with an x64 version of XP or Vista want to be a guinae pig? I have a small app and driver I would like to try.
    PM me if you are interested.
    Apr 2006
    Dallas, Texas
    I had the same issue. The fix is to set the target CPU to x86 from Any CPU.
    Software Developed:
    DS-ATX Controller Interface
    Laptop Shutdown Controller
    Considered Projects:
    TPMS Interface
    Bluetooth Handsfree Interface (WIDCOMM/BROADCOMM)
    Jan 2009
    Problem with first install of MDX Fusion software.
    I tried installing the MDX software. It looked like it was doing OK and put icons on my desktop. When I click on the "configurator" icon, I get a message that FCC Uber Configurator has stopped working...
    Whe I click on the Fusion Control Center icon, I get an initial message that "MDX does not have permissions to write to the registry. Please log in as an administrator" and subsequently, the default display appears for a few seconds. Then it closes and a message says " The Fusion Control Center has stopped working" I have installed the program twice and rebooted.
    I am the only user of this computer and am the admin. This is on my plain-jane Acer laptop running Vista Ultimate.
    Any ideas?
    Mar 2006
    Quote Originally Posted by partgypsy View Post
    Any ideas?
    Not to log in as administrator, but to run as administrator. You have to right click the shortcut, compatability, then check "run as administrator". Or everytime you run it you have to right click and choose "run as administrator". In Vista your account being an admin means diddly squat.
    This is because you have UAC enabled and is preventing the program from working correctly.
    Also if you are using an x64 OS, it wont work at all.
  1. Fusion Brain Latest Software MDX - Download Link
    By 2k1Toaster in forum FB Software
    Last Post: 05-12-2010, 08:52 PM
  2. Fusion Brain Software Feature Requests [VERSION 2]
    By 2k1Toaster in forum Fusion Brain
    Last Post: 01-07-2008, 06:18 PM
  3. Replies: 26
    Last Post: 12-23-2007, 09:12 PM
  4. Replies: 6
    Last Post: 12-23-2007, 12:27 PM
  5. Replies: 44
    Last Post: 12-09-2007, 12:37 AM
