Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 53
Thread: Fusion Brain -- Digital Encoder Beta Test
  1. #31
    Variable Bitrate quantum's Avatar
    Sep 2005
    Hey greenman100,
    Then count me in for one!
    TY
  2. #32
    Feb 2007
    Taylorsville, UT
    I would like one
    -James
    Car: 2004 GTI VR6 24v Turbo 2.8L, GT35R, 630cc, Unitronic, Bosch 044, etc, etc..
    Main PC:i7 920@4Ghz, 6GB DDR3, MSI X-58 Pro-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80
  3. #33
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by greenman100 View Post
    2k1's doing the soldering
    I will do the soldering, but you need to either get an encoder by ripping something apart or ordering a new one off of mouser.
    1.9in x 2.9in -- 47mm x 73mm
  4. #34
    Mar 2004
    Quote Originally Posted by 2k1Toaster View Post
    Alright, you guys still want one?
    I sorta still do, but I dont know if the beta boards would work any better than my current solution (which also has problems when switching directions). I've bought a buncha 'toys' in the last few days so I'm a bit iffy on spending more on something that might not be an improvement for me.
  5. #35
    Mar 2006
    Well no need to beta if you dont want to. Once the bugs are worked out, then you can buy a production one flaw-free.
  6. #36
    Mar 2004
    that's what I was thinking
  7. #37
    Oct 2006
    Las Vegas
    Here's my attempt at what goes where on the board.
    Would you clean up any mistakes and clarify jumper positions please.
    I'm unclear on the jumper settings for the encoder power pin.
  8. #38
    Mar 2006
    Yeah it is supposed to have silkscreen to show all pins, but they goofed it.
    Dont use the DC Jack... You will burn out the regulator. They put the wrong part on it, and the 3rd leg shorts power to ground... So power it through the brain. The power header isnt needed because I direct soldered the +5v from the brain to the power lines.
  9. #39
    Oct 2006
    Las Vegas
    Ok I did have to put a jumper on the top header, right where you had them in the picture. But I get it to work now. My voltage range is about 0-3.75V. I get about .3V per revolution on my encoder. But I can turn it around several times without a change in output. The rate at which I turn it makes a difference with the responsiveness. Once at the minimum or maximum voltage and turn further, it will go "around the world". obviously the bit shifts and looks like it starts all over.
    With regards to volts/rev, I suppose thats a resolution on the interface board vs. cycles/turn on the encoder, So I would have to get a different encoder which isn't preferred, but not out of the question.
    I'll video-record my trials later tonight.
  10. #40
    Oct 2006
    Las Vegas
    When I turn it really fast it works better, I'm assuming this was designed for an encoder with more "teeth".
  1. Fusion brain with 3000GT Steering Wheel Controls
    By TerraWombat in forum Fusion Brain
    Last Post: 02-22-2008, 01:27 AM
  2. Ordering Fusion Brain Today - Few Quick Q's
    By zzzBrett in forum Fusion Brain
    Last Post: 10-27-2007, 07:55 PM
  3. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
  4. BETA Test....
    By guino in forum Road Runner
    Last Post: 07-26-2005, 10:25 AM
