Is it possible to use the FB and it's attached sensors as a data-gathering tool?
The AutoAC system I have mentally visualized will rely heavily on an empirical model derived directly from thermodynamic data gathered in the vehicle.
In order to do that, I will need a fairly large data set, with points at various blower speeds and door positions under varying exterior and interior conditions (temperature and possibly humidity).
Is there a way to easily implement a sort of data-gathering mode that outputs all current sensor values to some kind of spreadsheet, Excel maybe or a CVS? Or will it be necessary to devise some kind of script that takes care of that for me![]()
2007 F-250 Crew Cab Harley Davidson - optioned out
Plans:
Completely blacked out exterior
Second Skin dampening
3-way active front stage
Full PC processing
2 JL 13TW5 subs behind rear seat
Completely stealth install
I guess I should learn to scroll down rather than just searching![]()
Plans:
Full PC processing
