Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: System monitor w/RoadRunner
  1. #21
    Oct 2006
    Ok, that sounds good. Shot the math into the calculators and seems good.
    Here is a "final" diagram of what i am going to be doing.
    This shows use of a LF353 from national semiconductor.
    http://www.national.com/mpf/LF/LF353.html
    I am going to run some numbers on what the sensitivity of the whole circuit is going to look like. I am hoping that this thing isnt gonna only be able to see a difference of 10 or 15 amps and be incredibly jumpy.
    Let me know what you guys think of the setup.
    Also, as far as input voltage into the LF353 and the FusionBrain itself, can i use un-regulated +12v from the vehicle, or would i need to use a voltage regulator?
    If it is not required, will it be benificial to add the regulator to get a more accurate read or more consitant output? Or will it not matter? The national semiconductor site lists 10-36 volts for supply voltage.
    Thanks everyone, especially greenman, you guys have been a ton of help!
    -Nick
  2. #22
    Apr 2008
    Baghdad, Iraq/Fort Bragg, NC/Saginaw, MI
    I'm not really good with electronics, but your best bet, for a "fluid" effect, is to ensure the output uses the full range, between 0 and 5v. IE, 0 amps = 0v, 150 amps = 5v... I'm sure theres a way to accomplish this... but most of my electronics work has been done via trial and error... IE, plugging things in, and seeing what happens =D
    peace
    Mike
  3. #23
    Fusion Brain Creator
    Mar 2005
    LF353 needs regulation, FB doesnt, they must share the same ground
  4. #24
    Oct 2006
    Any recommendations on what voltage i should run the LF353 at or is anything from 10-36 volts ok?
  5. #25
    Mar 2005
    a 9v reg should do fine
  6. #26
    Mar 2006
    Did this go any further forward guys, got a few uses for this circuit
  7. #27
    Oct 2006
    Sorry about the break in info guys.
    Had some personal stuff going on, and a promotion at work!
    Im going to get back on working on this module some more, keep tuned for updates
  1. New Russian GPS (Glosnass) available
    By MobiTekLink in forum GPS
    Last Post: 04-05-2007, 07:48 PM
  2. 2001 C5 Corvette Car Computer/Audio System
    By modena0 in forum Show off your project
    Last Post: 09-07-2006, 10:18 AM
  3. BUIDING VOLVO RTI NAVIGATION SYSTEM into VW
    By AndyB in forum General Hardware Discussion
    Last Post: 08-31-2006, 05:09 PM
  4. Ground audio system to battery??
    By eddie in forum Car Audio
    Last Post: 05-30-2006, 03:34 PM
