Results 1 to 3 of 3
Thread: Problem w/ digital outputs
    Sep 2007
    Raleigh, NC
    I recently purchased a fusion brain along with some relays. I finally found time to begin installing/configuring them. Just to fiddle/test out my new toy, I have set it up on my work bench connected to a 12v power supply. I created a very simple skin in mdx just to test out an auto on for my amp. I also linked the digital output to a button. When the skin loads, the led turns on, however the relay does not. I have tried all of the outputs with the same result. In an attempt to diagnose the problem I measured the voltage across the output when enabled and disabled, but saw no discernable difference in voltage.
    Am I missing anything obvious or is it possible that there may be an issue with my brain?
    Mar 2006
    Colorado, but Canadian!
    Make sure you match the output pin to the correct port: https://www.fusioncontrolcentre.com/...p?faq=Hardware
    They do not line up with the LED.
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2007
    Raleigh, NC
    Thanks that fixed it. I knew I had to be doing something wrong. rtfm I guess.
  1. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 11:50 AM
