Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: HOw to hook up an input to the FB
  1. #41
    Low Bitrate bigbuffs's Avatar
    Nov 2007
    OK so according to one of the media monkey programmers he says that the
    Filename: "mediamonkey.exe" (for skinned), "mediamonkey (non-skinned).exe" (for Non Skinned Version)
    Main Class: TApplication
    I tried these and several other possible combinations but I still get nothing. Any other Ideas? Here is the code used
    <?xml version="1.0" encoding="utf-8" ?>
    - <FusionControlCentreConfiguration version="3.0.0.0" author="Me" date_created="Saturday, June 14, 2008 at 1:28:05 PM" last_modified="Sunday, June 22, 2008 at 4:19:35 PM">
    - <require>
    - <!-- Begin Function Instances
    - <!-- End Function Instances
    - <!-- Begin Fusion Font Instances
    - <!-- End Fusion Font Instances
    </require>
    - <general>
    - <debug status="on">
    <virtual_brain id="mainbrain" />
    </debug>
    </general>
    - <graphics>
    - <!-- Begin Global Graphic Settings
    <main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="False" MinimizeToSystemTray="True" />
    - <!-- End Global Graphic Settings
    - <!-- Begin Background Images
    <background_image style="centre" imagefilepath="content\images\background_images\gr adient_01.png" page="0" />
    - <!-- End Background Images
    - <!-- Begin Static Images
    - <!-- End Static Images
    - <!-- Begin Variable Location Images
    - <!-- End Variable Location Images
    - <!-- Begin Graph Instances
    - <!-- End Graph Instances
    - <!-- Begin Display Buttons
    - <!-- End Display Buttons
    - <!-- Begin Multi Images
    - <!-- Begin Text Labels
    - <!-- End Text Labels
    </graphics>
    - <io>
    - <!-- Begin Fusion Brain Instances
    <brain id="mainbrain">usb\vid_04d8&pid_000c\6&3ab92d65&0& 4</brain>
    - <!-- End Fusion Brain Instances
    - <!-- Begin Timer Setup
    <timer id="input" interval="75" />
    <timer id="output" interval="100" />
    <timer id="gui" interval="50" />
    <timer id="logic" interval="50" />
    - <!-- End Timer Setup
    - <!-- Begin Digital Output Instances
    - <!-- End Digital Output Instances
    - <!-- Begin Analogue Input Instances
    - <iochannel id="swc" port="9" brain="mainbrain" type="analogue_input">
    <options history="0" auto_average="false" />
    </iochannel>
    - <!-- End Analogue Input Instances
    </io>
    - <logic>
    - <!-- Begin Logging Setup
    <all_logging />
    - <!-- End Logging Setup
    - <!-- Begin Variable Declarations
    <all_variables />
    - <!-- End Variable Declarations
    - <!-- Begin Logic Declarations
    - <all_statements>
    - <if fire_on="logic" minimum_delta_vote_time="1000">
    - <boolean_operation type="and">
    - <parameter1>
    - <boolean_operation type="less than">
    - <parameter1>
    <analogue id="swc" time="0" />
    </parameter1>
    - <parameter2>
    <number>2.5</number>
    </parameter2>
    </boolean_operation>
    </parameter1>
    - <parameter2>
    - <boolean_operation type="greater than">
    - <parameter1>
    </parameter1>
    - <parameter2>
    <number>1.9</number>
    </parameter2>
    </parameter2>
    - <then>
    <do function="Send Key" functionTargetID="mediamonkey.exe:TApplication" vote_opinion="Z" vote_priority="High" />
    </then>
    </if>
    - <parameter1>
    - <parameter1>
    </parameter1>
    - <parameter2>
    </parameter2>
    </parameter1>
    - <parameter2>
    - <parameter1>
    </parameter1>
    - <parameter2>
    <number>1.2</number>
    </parameter2>
    </parameter2>
    - <then>
    <do function="Send Key" functionTargetID="mediamonkey:TApplication" vote_opinion="S" vote_priority="High" />
    </then>
    </if>
    - <parameter1>
    - <parameter1>
    </parameter1>
    - <parameter2>
    <number>0.25</number>
    </parameter2>
    </parameter1>
    - <parameter2>
    - <parameter1>
    </parameter1>
    - <parameter2>
    </parameter2>
    </parameter2>
    - <then>
    <do function="Send Key" functionTargetID="mediamonkey:" vote_opinion="C" vote_priority="High" />
    </then>
    </if>
    - <parameter1>
    - <parameter1>
    </parameter1>
    - <parameter2>
    <number>3.3</number>
    </parameter2>
    </parameter1>
    - <parameter2>
    - <parameter1>
    </parameter1>
    - <parameter2>
    </parameter2>
    </parameter2>
    - <then>
    <do function="Send Key" functionTargetID="mediamonkey (non-skinned).exe:TApplication" vote_opinion="B" vote_priority="High" />
    </then>
    </if>
    - <parameter1>
    - <parameter1>
    </parameter1>
    - <parameter2>
    <number>5</number>
    </parameter2>
    </parameter1>
    - <parameter2>
    - <parameter1>
    </parameter1>
    - <parameter2>
    <number>4.3</number>
    </parameter2>
    </parameter2>
    - <then>
    <do function="Send Key" functionTargetID="mediamonkey (non-skinned).exe:" vote_opinion="NUM8" vote_priority="High" />
    </then>
    </if>
    - <parameter1>
    - <parameter1>
    </parameter1>
    - <parameter2>
    </parameter2>
    </parameter1>
    - <parameter2>
    - <parameter1>
    </parameter1>
    - <parameter2>
    <number>3.9</number>
    </parameter2>
    </parameter2>
    - <then>
    <do function="Send Key" functionTargetID="MediaMonkey:TApplication" vote_opinion="NUM2" vote_priority="High" />
    </then>
    </if>
    - <parameter1>
    - <parameter1>
    </parameter1>
    - <parameter2>
    </parameter2>
    </parameter1>
    - <parameter2>
    - <parameter1>
    </parameter1>
    - <parameter2>
    <number>3.4</number>
    </parameter2>
    </parameter2>
    - <then>
    <do function="Send Key" functionTargetID="MediaMonkey.exe:TApplication" vote_opinion="C" vote_priority="High" />
    </then>
    </if>
    </all_statements>
    - <!-- End Logic Declarations
    </logic>
    </FusionControlCentreConfiguration>
    HELP ME!
    [||||||----] - 60% Complete
  2. #42
    Mar 2006
    Colorado, but Canadian!
    Try ":TApplication"
    I will see if I can make something temporary for you... Will this program always be "ontop"?
    1.9in x 2.9in -- 47mm x 73mm
  3. #43
    Mar 2006
    http://www.fusioncontrolcentre.com/T...ound%20Key.rar
    Download that and unrar the exe. Replace the current exe in the installation folder. Change your voting commands from "send key" to "send key to foreground"
    This will just blindly press a key. The key field (vote opinion) should be a single letter, try capitol letters first. So if the FCC window is in the foreground it will send it to FCC. If your other program is in the foreground and focused, then that is where it will go. If this doesnt do it, then the error isnt with FCC.
    Also you will need the .NET 3.5 Framework from now on
  4. #44
    Nov 2007
    I tried TApllication but that didn't work. I'll give your stuff a try and see what happens. Do I just leave the taget blank then so it should look like this right
    <do function="Send Key To Foreground" functionTargetID="" vote_opinion="C" vote_priority="High" />
  5. #45
    Mar 2006
    No you do need something in the targetID, but it wont be used. just put in "filler" or something.
  6. #46
    Nov 2007
    Looks like like it's working. This is actually how I wanted it to work because now I can use the SWC to navigate through the desktop and stuff like that. Is there a reason that you left out certain keys in the program such as "enter"?
  7. #47
    Mar 2006
    Quote Originally Posted by bigbuffs View Post
    Only keys purposely left out are ALT/SHIFT/CTRL sequences as I cant get them to work right at all.
    I just didnt think enter was a key one would use as a hotkey, but I can put it in if you want it.
    So just confirming, it works right? Happy happy joy joy then!
  8. #48
    Nov 2007
    yes it works thank god. Now if I want to have it set up to control RR would I just send the keys to winamp or does it have to go to RR.
  9. #49
    Mar 2006
    You can do either. It is best to send to winamp, and winamp support is built in. Just put the targetID as "winamp" and the program will do the rest.
    If you want to send it to RoadRunner, put in its title. I am not 100% sure with RR itself but I think the title is just "RoadRunner"... Maybe it has a space, I have not checked as I send to winamp directly.
  10. #50
    Nov 2007
    well I tried sending it to winamp and it works when just winamp is running but if I have RR running then I get no response.
  1. Pioneer AUX input problem
    By grunar in forum General Hardware Discussion
    Last Post: 12-02-2008, 02:43 AM
  2. Replies: 10
    Last Post: 06-07-2006, 09:13 AM
  3. Problems with XM input thru any front end
    By CyberLogic in forum Software & Software Development
    Last Post: 05-07-2006, 01:49 PM
  4. 8" touchscreen Lcd input question?
    By kitt350 in forum LCD/Display
    Last Post: 04-02-2006, 03:10 PM
  5. can I use an amplifier for rca input??
    By sheriff in forum General Hardware Discussion
    Last Post: 03-23-2001, 08:03 AM
