Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
Thread: HOw to hook up an input to the FB
    Low Bitrate bigbuffs's Avatar
    Nov 2007
    OK so I can't quite figure out how to physically hook up an input to the FB. I'm trying to hook up my steering wheeel controls and I have them all ready to hook up (used a voltage divider and one wire outputs signals below 5v).
    I can't find a diagram that shows the FB and where each wire goes. Do I need to hook up to the red wire poles? How do I do this?
    [||||||----] - 60% Complete
    Fusion Brain Creator
    Mar 2005
    Nov 2007
    exactly what i was lookin for thank you
    Nov 2007
    I'm still not sure on how to hook up the wire. Does it run across all three of the analog input prongs or does it just need to touch one of them?
    Mar 2006
    Colorado, but Canadian!
    Since you have your own power and ground already, you only need to use 1 wire. The 1 wire from your steering wheel controls onto the Input Pin of an analogue input. The +5v and GND on the Fusion Brain are meant to power sensors and such.
    Also since you are doing steering wheel controls, you are probably the first guinae pig I have for the new dTime feature in MDX added 5 days ago. This way you can set how rapidly the buttons fire the software and the new imporved key sender as of last night too. Let us know how you do.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2007
    Awesome, I think I got it figured out I'll let ya know how it goes.
    Nov 2007
    i'm having a problem getting my computer to recognize the FB. Everytime I plug in the FB the install new hardware wizard comes up. If I try to install it automatically it says windows can't do it. I try to install from a specific location but I can't find the right place. The files in the driver folder dont show up when I try linking to them. Anyone know what Im doing wrong. I'm running XP
    Nov 2007
    OK got the drivers installed now just trying to get the SWC setup
    Nov 2007
    OK, how do I know if I have the SWC wire hooked up correctly and if the FB is reading it or whatever.
    Nov 2007
    I think I'm starting to understand how to hook up the wire. It looks like with the analog input, each of the 10 inputs has 3 prongs. Do I need to hook up anything to the 5v dc pins and the ground pins or do I just hook the wire up to the last pin, the input pin?
  1. Pioneer AUX input problem
    By grunar in forum General Hardware Discussion
    Last Post: 12-02-2008, 03:43 AM
  2. Replies: 10
    Last Post: 06-07-2006, 10:13 AM
  3. Problems with XM input thru any front end
    By CyberLogic in forum Software & Software Development
    Last Post: 05-07-2006, 02:49 PM
  4. 8" touchscreen Lcd input question?
    By kitt350 in forum LCD/Display
    Last Post: 04-02-2006, 04:10 PM
  5. can I use an amplifier for rca input??
    By sheriff in forum General Hardware Discussion
    Last Post: 03-23-2001, 09:03 AM
