Results 1 to 10 of 13
Thread: Brain going grazy?
    Newbie yellow99's Avatar
    Dec 2004
    The Netherlands
    Brain going grazy?
    Ive created this thread in the hope to get e quicker response (maybe from another forum user.)
    I ordered 3 brains and received them a few days ago.
    Whey i hook one on to my computer and run an instance in debug mode i get really strange values from all the analog inputs at the same time.
    To show you what i mean i created a short movie
    I don't have any sensors connected to the brain.
    I have the same results with all 3 of the brains.
    Could someone tell me what i am doing wrong?
    Or are all 3 my brains broke?
    kind regards
    Pieter
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by yellow99 View Post
    At a rough guess:
    The inputs are floating. Does it behave itself if you attach something to the input?
    Dec 2004
    The Netherlands
    Quote Originally Posted by Rob Withey View Post
    If i connect a temp sensor (for example) it behaves the same way...
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i'm sure the guys will be here soon to explain this in detail but this is common... i see the same thing on my fusion brain if nothing is connected. and if i have a single sensor connected the inputs around that analog in will flicker. Nothing out of the ordinary
    Live mp3Car Facebook Chat
    Oct 2006
    Las Vegas
    something to try:
    If you have several jumpers (PCB header style .1") try connecting them from ground to sense on all of the unused channels and put a temp sensor on 1 input that you leave un-jumpered. See if that stabilizes things.
    Dec 2004
    The Netherlands
    Quote Originally Posted by Sonicxtacy02 View Post
    Ok now i tried connecting 3 temp sensors to the brain at the same time...
    Ive connected a temp sensor to port 01, port 05 and port 10
    (please see video) still port 1 and port 10 keep on jumping in value?
    Also. In the example that is included to Uber MDX there is a inside and outside temperature showing that reads the temperature of port 1 and port 2
    when i connect 2 temp sensors to those ports and start up this example i get really long values:
    When you look at the screen shot in the FAQ at fusioncontrolcentre.com it shows short values:
    Does anyone know why this happens?
    Dec 2004
    The Netherlands
    Quote Originally Posted by h3rk View Post
    something to try:
    This seems to work! i only have 3 jumpers at home right now and ive put them on port 2, port 3 and port 4. On port 1 ive connected a temp sensor (see results here)
    I am going to the shop for more jumpers..
    Still does anyone have an answer for the long numbers in the example? (see post above)
    Thanks so far
    Woodbridge, VA
    Blog Entries
    55
    long numbers just say to me its a configuration issue. Tho i've never done any configuring in MDX or FCC so i cant say for certain
    Dec 2007
    I had the same problem with the long numbers. It was the way I configured the inputs. Learning curve is a little steep in places. But after you figure it out it is a dream to set up. I suggest reading all the posts. Even the ones you don't think have anything to do with what you want the FB to do. There's lots of good info here.
    Mar 2006
    Colorado, but Canadian!
    Floating ports are common. They dont do any harm. As soon as you attach a sensor, it stops floating. If there is no sensor, then why are you monitor it? Pretty much just leave it.
    The 20.48xxxx is because you did not set the decimal precision. The textbox that says how many decimals to show. And that is the correct value for 0v being read in. It is actually -20 but that font file has no hyphen.
    Are you sure you connected the temp sensor to the right port? If you sort of "squeeze" the pins lightly with your fingers you should be able to see the value change. Dont squeeze like a madman but just sort of go from the outermost to the innermost pins. Bring up a virtual brain and see what is going on there.
    1.9in x 2.9in -- 47mm x 73mm
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  4. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  5. Brain cells CAN reproduce!
    By XxAndyxX in forum Off Topic
    Last Post: 02-28-2007, 07:55 PM
