Results 1 to 4 of 4
Thread: Home Automation FB project....
    Nov 2004
    Hi all, dont' know if this belongs here but I'll try...
    Well, being very active on this site with my car computer and coming across the Fusion Brain and its popularity, I'm wondering if I can apply it to control my espresso machine. Pretty much, the machine has one on/off switch that controls the boiler and another on/off switch that controls the brewing or extracting of coffee. The overall goal of the project is to set the espresso machine on a timer (via software on the PC) and then have it make a cup of espresso in the morning ready for me to pickup before work. Future ideas are having it work via the internet. I'm pretty sure I'll be able to implement the on/off simulation of the switches with the FB but how about the timer portion of the project? If not, is there a way to interface the FB with say a Visual Basic program or some other programming language? Thanks!
    Jun 2008
    Georgia, USA
    Take a look at the FB homepage and you'll see that is one of the things it is used for.
    You can certainly write your own code. Just look at the documentation for the FB low-level interface. It explains the datastream.
    Thanks,
    Dan
    Mar 2006
    Colorado, but Canadian!
    Yes it will work.
    If you want to write your own software, then you are welcome to use the DLL we provide. There are examples around here written in VB and then the low level interface document will explain how it works in more detail if you want to know.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    To elaborate, you'd just need the Fusion Brain, and two relays. The rest is done on the PC, via the Configurator software.
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 09:44 PM
  2. PC harddrive connected to laptop for home project
    By mrhic2 in forum General Hardware Discussion
    Last Post: 03-30-2006, 12:38 AM
  3. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 06:46 PM
  4. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
