Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Questions about functionality and usage
  1. #11
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by RedGTiVR6 View Post
    Thanks for the info guys.
    I plan on reading through the tutorials and everything today for the software. Naturally, I'm going to start out small and work my way up with this. Seems that a background in electrical engineering would help out tremendously if you're wanting to try different sensors.
    Regarding the current sensor, I'm assuming you hook this up in series with the line you're trying to measure, correct?
    Looking at the specs for the 200 amp sensor, we're seeing that the physical dimensions are identical, which is strange. We're just a little iffy about running that much current through one of these things...lol
    Ideally, we want to be able to run a sensor on each amplifier, as well as temperature on either side of each amplifier.
    The amps I have already have built in monitoring, however, it's kind of a beta thing....the drivers for them don't really work and since I'm not a driver person....
    50 amps is the absolute maximum. You'd probably run 30A RMS through one...and you'd want to coat boat sides of both terminals with solder once you put the wires in there.
    Take a 300W amplifier apart and look at the PCB connections. Probably not a whole lot more substantial...
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    A typical 300 watt amplifier...yes.
    ....one that really only puts out 300 watts at max power... hehe
    If it's going to handle it, I guess I'll take your word for it.
    Our amplifiers each have 80 amp fuses, so I need to make sure this isn't going to cause problems if I run the 100 amp sensor. The computer, I'm not worried about, this 50 amp sensor should work great for that.
    Jan Bennett
  3. #13
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    ahh i only skimmed too.. thought you were talking about the FB itself.
    should read more carefully
  4. #14
    Mar 2005
    You need to find a sensor that's rated at at least 100A if your device is fused at 80A fastblow.
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    Right - and that's what I've been saying....
    Jan Bennett
