Results 1 to 5 of 5
Thread: Fluctuating Input Values
    Newbie thwack's Avatar
    Sep 2005
    Adelaide, SA
    Hi all,
    I am having trouble understanding where my issue is coming from.
    Basically I am measuring the voltage of my cars two batteries.
    I have setup a voltage divider for each with a 330ohm and 100ohm resistor.
    This gives an output of 2.91v when the battery is ~12.46
    for each the scaling factors are
    1. 0.2341920
    2. 0.2325581
    But the raw input values seem to fluctuate anywhere from 480 to 780 randomly even though the input voltage has not changed. I can stick the multimeter across the end and get a constant 2.67-2.68V stable, yet the display is showing anywhere from 1.76V to 3.8V
    I have tried multiple ports and this still seems to happen on every one. Even if I change the resistance to give a smaller value it is still happening.
    I am also running two temp sensors and these appear to be working well with stable values.
    What am I doing wrong or what can I try next??
    thanks
    Thwack
    Car PC -Jetway J7F2WE2G, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
    Car- 1988 Nissan Patrol 4WD
    Fusion Brain Creator
    Mar 2005
    When did you buy it?
    Sep 2005
    Adelaide, SA
    30th July This year
    Sep 2005
    Adelaide, SA
    Would a capacitor from Vin to GND help filter out the fluctiations?
    Mar 2005
    I didn't see that you're using temperature sensors with stable values. That means it's not the FB's fault.
    A capacitor or noise filter would help, yes.
  1. Phone style text input applet (with Source code!)
    By Dominik in forum Software & Software Development
    Last Post: 05-19-2008, 06:58 PM
  2. Replies: 2
    Last Post: 11-29-2006, 09:58 AM
  3. Xenarc - OSD with no input?
    By John M in forum Newbie
    Last Post: 11-20-2004, 07:08 PM
  4. Im Not Too Sure About These Inputs Input Needed Plz!
    By Dave Lobster in forum LCD/Display
    Last Post: 08-14-2004, 03:05 PM
  5. can I use an amplifier for rca input??
    By sheriff in forum General Hardware Discussion
    Last Post: 03-23-2001, 09:03 AM
