Results 1 to 3 of 3
Thread: Ultrasonic Distance Sensor idea.
    Aug 2005
    Looking at installing the Ultrasonic Distance sensor in my side view mirror facing down. The idea i wan't is to play an audible warning when I get to close to curbs on the passenger side when parking.
    My thinking is it will be able to sense the raise in height when its over the curb as the mirror sticks out a good 10".
    Will this work? How hard is it to achieve?
    Cheers
    Nov 2007
    Quote Originally Posted by SKiTLz View Post
    Cheers
    Preface by saying that my experience with the sensor is limited. I played with one of them most of the weekend, off and on.
    What you want to do may work, kind of. The problem is that the sensor sends out a cone shaped signal. The signal is not a narrow column that can accurately sense where an edge is entering perpendicular to the signal(i.e. will not tell you how far to the side but will tell you the distance to the top of the curb). Plus, you might end up picking up something on the side of your vehicle. What really makes it interesting is that it might pick it up now but not later and then pick it up again. In other words, it does best if the object comes into range within the cone and parallel to the signal, like in backing up toward another car with the sensor mounted parallel to the ground in your back bumper.
    You might get better results if the sensor were mounted lower (cone is smaller) or mount somewhat low and parallel or near parallel to the ground.
    Something to consider, although probably a bit pricier. What about a remote camera aimed down so that you can see the side of your tires. That way you get a visual of how close you are. If you are really tricky, you could mount it on the bottom of your mirror on a remote controlled tilt/swivel mount and it could serve dual or multi purpose.
    Mar 2006
    Colorado, but Canadian!
    Actually for this application an IR sensor would work but lower on the car since the range is not as long.
    The Ultrasonic sensor uses sound waves, and does go in a "cone" type shape. The IR however is a narrow narrrow beam straight down (it is light).
    1.9in x 2.9in -- 47mm x 73mm
  1. Custom USB Parking Sensor interface (formally PDC-USB)
    By Robby BMW in forum Hardware Development
    Last Post: 01-16-2012, 01:45 PM
  2. RRPDC - RoadRunner park distance control extension plugin
    By Robby BMW in forum RR Released Plugins
    Last Post: 06-11-2011, 02:15 PM
  3. police laptop\radio frequency
    By jdogg1583 in forum Hardware Development
    Last Post: 03-31-2008, 05:32 PM
  4. Circuit for Ultrasonic (Parking) Sensor
    By Nerd2 in forum General Hardware Discussion
    Last Post: 01-20-2008, 01:19 PM
  5. Replies: 2
    Last Post: 07-07-2006, 05:38 PM
