Results 11 to 20 of 27
Thread: Finally received my Brain!
  1. #11
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    Downloaded the entire 9.0c package (80mb) from Microsoft and installed it, plus a restart (to let the MDX updater sort itself out) and now I just get this when I load the Uber MDX:
    Im going through the config making sure all the paths match up, Ive tried saving to the Fusion folder in Program files as well as the MDX folder within that, but I still meet this big blank screen.
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Can you change your regional settings to US instead of Poland and see if anything changes?
    Also the .NET package needs language files for different ones. I only have it download the English files. Try to download the english .NET 3.5 redistributable.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Sep 2005
    Warsaw, Poland
    That's given me something back:
    And the NET packages are all in English, the regional settings were for the UK first, now they're at US.
    Maybe a complete uninstall-reinstall would help, but as I have to be at work in 7 hours, Im off to bed. Thanks for the patience
  4. #14
    Sep 2005
    Warsaw, Poland
    Well I uninstalled MDX, deleted the folder, restarted, reinstalled, ran the Ninja again and I get the same results.
  5. #15
    Sep 2005
    Warsaw, Poland
    Uninstalling and reinstalling the Brain so that it is definately v3 (rather than updating the driver) has produced something - the grey squares that represent digits on the white screen are flickering and moving, so MDX is definately in communication with the Brain and taking readings - I just don't know what the readings are!
  6. #16
    Sep 2005
    Warsaw, Poland
    Ive also found that if I make a configuration file with the Ninja I get a screenshot of what it SHOULD look like in MDXC. If I save it and then immediately reload it, the grey button graphic where the read data should be has turned into a pure white square. Is this related? Has anyone else suffered this too? Im 24 hours in and not even on Step One yet And this is testing with two Brains and two sensors.
    If I tell the configurator I have a Virtual Brain then I get that to display in all its glory in MDX, although I still get a blank screen in the MDX main window.
  7. #17
    Mar 2006
    Quote Originally Posted by Grrrmachine View Post
    Wait wait...
    If you use a Virtual Brain it works, if you dont it doesnt work? Screenshots? The 2 parts on non-related at all. Completely seperate. Only time it would error is if it is erroring all the back at config time.
  8. #18
    Sep 2005
    Warsaw, Poland
    Quote Originally Posted by 2k1Toaster View Post
    Wait wait...
    No, if I use a Virtual Brain I get the virtual brain window that allows me to inject values, but either way (virtual or real) the MAIN MDX window remains blank, white, empty, like the last screenshot I gave.
    It suggests the main MDX application is running: it knows I want to use the brain, but its just not finding the graphic files it needs, even though there's a valid Content folder for the configuration file.
  9. #19
    Mar 2005
    do you have access to a different computer you can try it on?
  10. #20
    Sep 2005
    Warsaw, Poland
    Yeah, I'll try the virtual and real system on a clean laptop I have, but it'll mean downloading the ultimate package (286mb) which will take a while.
    So whilst I do that, is there any way a previous installation of MDX is corrupting things? I can't believe its my graphics driver as everything else on this system works fine. Any other dependencies I ought to update?
  1. Renault "Tuner List" Head Unit/CD changer hacking - Controls
    By Vicne in forum Hardware Development
    Last Post: 12-31-2011, 05:58 AM
  2. bluetooth woes
    By gentoocar in forum Linux
    Last Post: 12-12-2009, 04:05 PM
  3. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  4. FS/FT: Monitors, Motherboards, Cell Phones, Printers, Misc
    By Rafster in forum Classified Archive
    Last Post: 01-16-2007, 05:46 PM
  5. Help!
    By WRX2001 in forum PhoneControl
    Last Post: 01-25-2005, 04:50 PM
