The USPS... They're not the only ones "going postal", they drag you down with 'em!![]()
After two months, delayed orders, USPS's finest and Poland charging 22% import tax, I finally got my hand on a Brain and a load of sensors to try out! Im stupidly excited (more than I should be) at the possibilities this thing could provide. Now I just have to get to grips with the software: I'll chart any problems I find along the way. I've not been reading the forums lately, so Nick, Tim; consider this a Guinea Pig Guide to a Fusion Noob's Experiences...
Play with it, 'til it's broke.
Glad you got it! I dont know why USPS is being so slow lately. We have had quite a string of bad luck between USPS getting orders to people (even domestic US) coupled with an abnormal amount of Chinese Holidays screwing up and delaying our orders...
Hopefully this will stop happening!
1.9in x 2.9in -- 47mm x 73mm
Ok, so I've fiddled around a bit, found a power source (were there any plugs connected to the barrel sockets provided, or did the Polish post office chop them off?) and got the Brain lit up. I have an eerie blue glow to look at.
Next off was downloading the updated software, which was rather easy, including updating the Brain driver to v3 (use the driver folder, duh.)
Now I'm fiddling with the Kitty Ninja Wizard. Telling it that there's one Temp Sensor connected to one Brain, using the default template, the configurator shows a cheery blue demonstration of what the software should look like running (left) whereas actually running Fusion Control produces this (right):
I've also noticed that if I go back into the Wizard, it will tell me that I have no Brain connected and that Im not using the LibUSB driver; disconnecting and reconnecting the Brain cures this, but it's not an elegant solution.
And if I try to load the saved config again in the Configurator, I get this message:
"Could not bind all text instances to font instances in this config file."
So these are the first teething problems (aside from someone not knowing how to use apostrophes)
I am saving directly to that directory, and the content folder is there too, so I don't know why Im getting a white screen with one grey cell.
Put the command line switch "-basicgui" on the program shortcut and see what happens (with a screenshot preferrably)
You did install DirectX9.0c right?
Refreshed DirectX just to be sure, added that command line, now Im just getting a completely blank screen when I run the Control Centre, even though the Configurator reloads the xml just fine.
