Results 1 to 10 of 13
Thread: Fusion Brain Encloser
    Jan 2006
    Ive been wondering, for those who have already placed the Fusion Brain into their vehicle; what did you use for a casing?? I had a few ideas but they didnt work to where i want to place the fusion brain. im not much worried about the relays because they are going to be mounted seperate, but im worried about the fusion brain just laying around in the car without any sort of protection. thanks!
    Jan 2006
    no one made any sort of casing for it???
    Sep 2005
    Australia
    That's exactly what I was thinking. It would be great if someone could CAD one up, get a rapid prtotype made then use that to make a silicon mould. With every mould you can make about 100 copies, then a new mould has to be made. This is more cost effective than getting a die made up which could be alot of $$$$.
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    I went to walmart and bought a small clear plastic storage box. It is about 8" x 5" x 1.25". I used a dremel tool and a knife to remove some of the dividers, and knocked a couple holes in it to get some cables in and out. It doesn't look pretty, but it allows me to see what the output lights are doing when I'm using it. I mounted the relays in a different place. They are in a kitchen cooking container, also made of clear plastic, but that one has a water tight lid.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i used a radio shack project box.. aint pretty but it doesnt need to be.
    Live mp3Car Facebook Chat
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Quote Originally Posted by Sonicxtacy02 View Post
    Any pics?
    I run mine naked on top of a black plastic along with all the relays and wires on there.
    My carpc worklog
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by rgarjr View Post
    Any pics?
    http://www.radioshack.com/product/in...entPage=search
    just cut some holes to run wires thru
    Jan 2006
    Thanks for all the reply's, but I actually ended up not making any sort of case for it, because where i mounted it would not be visable anyway and I mounted it on plexi-glass, so no chance in it touching anything!
    Jun 2008
    Georgia, USA
    Quote Originally Posted by djurchicprelude View Post
    I wouldn't use plexiglass as it is a static-generating material. The same goes for the plastic box from Wal-Mart mentioned earlier.
    Your best bet is to use a Radio Shack project box as they are made from non-static materials and are designed to house electronic projects.
    Thanks,
    Dan
    Jan 2006
    Quote Originally Posted by Dan2008 View Post
    Never thought about that. Thanks for the heads up!
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 3
    Last Post: 09-23-2008, 10:00 PM
  3. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  4. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
