Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: New To Fusion Brain
  1. #11
    Mar 2008
    i also tried this
    <!-- Begin Fusion Brain Instances -->
    <brain id="FB Car">0</brain>
    <!-- End Fusion Brain Instances -->
    Didnt work
  2. #12
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    Quote Originally Posted by Urbanmindz View Post
    ...when voltage between 4v and 6v is applied to analog input 0...
    If you really did feed it something over 5 volts at some point, that may be the problem. The chip is only designed to measure 0-5v, but I'm not sure what happens when you go over 5v.
  3. #13
    Mar 2008
    ive never gone over 5 volts.. when i start the default xml (the one that preinstalls), when i apply voltage under 5 volts (check with a multimeter) several inputs react to the single input voltage. I am not sure if this is supposed to be this way..
  4. #14
    Aug 2003
    Iowa
    Yes, that is normal. The analog to digital converter loops through the analog inputs, and if there is nothing connected to an input, some voltage will carry over from the previous input. It's not a problems since you won't be monitoring an input without anything connected. If it bothers you, just put a jumper between the ground and sensor pins.
  5. #15
    Mar 2008
    lol doesnt bother me at all just wondering if it was a sign of malfunction. so if i get voltage reading on the default XML then in theory my FB is working fine right?
    Still wondering if anyone has a working steering wheel XML for me to study because apparently i am doing something wrong.
  6. #16
    Fusion Brain Creator
    Mar 2005
    if you're getting accurate voltage readings, the brain's doing its job.
  7. #17
    Mar 2008
    I realize that the brain is doing its job but i cannot get it to send a keystroke for nothing in this world. all i am trying to do is create a simply test XML that senses voltage on AI0 and sends control shift c keystroke to centrafuse and when the voltage releases for it to send control shift b. this is to activate a reverse camera. I thought this would be more simpler than creating the steering wheel control first. Can someone, anyone help me out? please???
  8. #18
    Mar 2006
    Colorado, but Canadian!
    use a simpler keystroke than ctrl+shift+c. Change it to something like "r".
    1.9in x 2.9in -- 47mm x 73mm
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 3
    Last Post: 09-23-2008, 10:00 PM
  3. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  4. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
