Results 1 to 6 of 6
Thread: Sending SWC to RoadRunner
    Low Bitrate bigbuffs's Avatar
    Nov 2007
    I'm trying to send my SWC to roadrunner using the FB. I have it working with winamp but I'm not sure if I need a specific title name for roadrunner. I've tried RoadRunner and RoadRunner.exe. I also tried using the send key to foreground method but MDX tells me that is not a valid "what to do" choice or something like that.
    [||||||----] - 60% Complete
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by bigbuffs View Post
    Use the send key vote in the configurator, and then if you want to send to foreground, change it directly in the XML. Where you see "send key" change it to "send key to foreground".
    That would be the easiest way.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2007
    is there a way to send it straight to RR or will that not work?
    Mar 2006
    You can send it to RoadRunner directly if you want to.
    Easiest is to have RoadRunner running, use the configurator, and drag the crosshairs over to RR and capture the info.
    Mar 2006
    Ok, there will be a new way in the next release. I am playing with it now, but basically you will be able to use the COM interface and talk to RoadRunner directly. So you will be able to send "PLAY" to RoadRunner and have RR interpret that command or "UNDERPANTS" and RR will figure out what you sent which should make things much easier.
    Mar 2006
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 08:29 AM
  2. RoadRunner not sending play list to winamp?
    By Arathranar in forum Road Runner
    Last Post: 06-23-2008, 04:06 PM
  3. RoadRunner not sending play list to winamp?
    Last Post: 06-19-2008, 09:32 PM
  4. Music in roadrunner
    By m60power in forum Road Runner
    Last Post: 04-24-2008, 10:21 PM
  5. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
