Results 1 to 10 of 10
Thread: problems with drivers
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    When I try to add the brain in the configurator, it says " drivers not installed, LibUSB DRIVERS NOT INSTALLED PROPERLY. I down loaded the all the software and drivers, do I need to put them in a special place or something? Da fusion brain show up in the device manager , working properly. whats the deal?
    Fusion Brain Creator
    Mar 2005
    "da fusion brain" is the old drivers. use device manager to update to the newest drivers, located in your MDX install directory.
    Oct 2005
    Quote Originally Posted by greenman100 View Post
    thanks, I got it to work
    Oct 2005
    Since I got it to work, I added a analogue input ( steering wheel control). how do I list or put all the values of each button press and what program class to use?
    Mar 2005
    Oct 2005
    I already know how and have the values for each button. I need to know how to plug them in on the configuator? thanks
    Mar 2005
    Quote Originally Posted by customaudioman View Post
    look at the last post in that thread.
    Mar 2006
    Colorado, but Canadian!
    And if you are using RR, you can now use the COM object to send it directly to RR without keyboard emulation. You can read up on that here: http://www.mp3car.com/vbulletin/fb-s...ig-update.html
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2005
    Quote Originally Posted by 2k1Toaster View Post
    what about streetdeck? problem I found in the past when I tried a year ago was the class changed every time I open the program.
    Mar 2006
    You can use the send key to foreground which works in any app without needing to know class name or anything.
    Or you can use send key with just streetdeck and it will search open windows for one with "streetdeck" in its title/class automatically and send it there.
  1. Replies: 33
    Last Post: 03-28-2008, 03:18 PM
  2. Help. Having problems with my video drivers. Acts glitchy!
    By isamu in forum General Hardware Discussion
    Last Post: 10-11-2007, 05:56 PM
  3. Harddrive problems (booting)
    By Axxess in forum General Hardware Discussion
    Last Post: 05-15-2007, 05:13 PM
  4. Replies: 6
    Last Post: 04-01-2005, 05:22 AM
  5. Xenarc 10.4" touchscreen problems
    By basscoholic24 in forum LCD/Display
    Last Post: 02-25-2005, 10:47 PM
