Results 1 to 10 of 11
Thread: question about ac/heating controls
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    I have dual climate control in my 2003 honda accord. Sine I have a carputer I no longer use the factory radio/cd player. I want to remove it from the center dash, problem is that the climate control are built into the head unit. Can I just remove the whole thing and use the fusion brain and display the temp on the vga screen? I want to be able to control it with out the ubit in the car. I know I have 8 buttons and two rotary knobs that control the climate control. Has anyone done this yet? if yes do you have pictures or links?
    Sep 2005
    Australia
    There are 2 directions you can take (in my opinion):
    Ideal for newer more complicated HVAC systems
    1. Retain your original climate controller and just tap the signals off the rotary dials and buttons and connect them to the Fusion Brain. This way you will retain all your factory climate features, and with a bit of logic you should be able to work out the temp from the position of the rotary dials so you can display it. Though you will just have to relocate you original climate unit and add a bit of interface hardware.
    Good for older simpler HVAC systems
    2. Remove the climate controller completely and add some temp sensors to the Fusion Brain. This way you can make up you own algorithm to control your temp, then you have complete control over the blower and temp. This method requires much more hardware interfacing.
    Have a look at h3rk posts, he has done a huge amount of work on this subject and you should get some ideas from this guy.
    Oct 2005
    Quote Originally Posted by Civic Modz View Post
    well the problems is the ac/headunit is all one large part. I dont know where I can relocate it to. If look at my avatar you see the picture of the built in ac/headunit, it the whole center part
    Sep 2005
    Australia
    Maybe you could open the whole thing up and you might find that the climate unit is a small module inside the head unit. I doubt that the circuitry for the head unit will be intergrated with climate system. Pull it apart and you should be able to tell.
    Oct 2005
    actually I had the whole thing apart when I painted. The size of the whole radio system/ac climate control which is a cpu board, is the same size of the whole thing. That the reason I have never seen anyone do it for honda accord 03-07
    Sep 2005
    Australia
    Hmm, maybe I was wrong then. I was looking at this:
    03-05 Accord 7" Mold
    and I think that green plug in the pic goes to your climate controls cos in my civic its looks like the same plug. If you have a schematic of the electronics of the climate and/or radio post or PM it, and i will look at it. If there similar you might be in luck.
    **ADDED, goto second last post of the above thread and there is a link with pics on what some guy did and relocated his climate.. This should solve your problem.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by customaudioman View Post
    You can't find anywhere to stash the thing and extend the wires? I know in my civic, there are huge cavities in the dash and centre console so the curvy plastic looks nice.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2005
    I dont thinks so. If I want to keep the plastic on the front trim. you have take it completely apart, a pain
    Sep 2005
    Australia
    So I take it you want to completely remove the climate control unit including the dials right, and have the FB control everything?? If this is the case then yes the FB can do it, though you will have to know where all your vent controls are in order to control them, then just have an external temp sensor or use the factory one. Then you have to control the blower motor. So yes there is a bit a work ahead of you if this is what you want to do. If you really need help post a diagram of your climate system if you can find one.
    Jan 2009
    Buy the Metra aftermarket radio dash kit and it has an "aftermarket" heater control to go along with new radio. cut out the radio housing and wire up the heater control. now smaller to stash somewhere nice
  1. E46 1999 323Ci Cannot move heater controls
    By SphinX2008 in forum Newbie
    Last Post: 03-21-2008, 01:38 AM
  2. Ford HVAC Controls
    By brandname2007 in forum General Hardware Discussion
    Last Post: 12-31-2007, 03:56 PM
  3. Music Controls missing after module change
    By sjmanikt in forum StreetDeck
    Last Post: 05-23-2007, 10:50 AM
  4. Redesigning the 2002 Chevy Suburban A/C Controls
    By TheDeepFryedBoo in forum Hardware Development
    Last Post: 12-21-2006, 02:12 PM
  5. Replies: 2
    Last Post: 05-23-2006, 12:56 PM
