Results 1 to 10 of 12
Thread: Skin Programming
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Skin Programming
    I was working on a climate control skin a while back when we were working with just the Alpha version (non-MDX) and just starting with the multi-image stuff and all. I kinda faded away for a while due to work and life but I have some time now to get into this again. I have a different car now so as of now I don't need to get to complex with climate controls, but as i've been playing with MDX it seems that the programming from Alpha-non-MDX doesn't work. I can't seem to really figure out the Configurator program plus i like to just write the config file myself.
    Basically I was wondering if you could just quick write out a quick instance in the skin code for me?
    One that I need is: IF Variable_Analogue_Input_0 < 3 THEN switch Digital Output 1 ON
    Also... IF Variable_Analogue_Input_0 < 3 THEN roadrunnercommand_stop
    I hate to be bother and ask newbie questions and ask for code lines but i think with these 2 I should be pretty set. Thanks for the help!
    Mar 2006
    Colorado, but Canadian!
    For the RR Command part: http://www.mp3car.com/vbulletin/fb-s...ig-update.html
    And you are more than welcome to write the code yourself instead of using the configurator.
    To get the syntax down, maybe using the configurator and seeing the code it generates would be useful for you.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2007
    Haledon, NJ
    That recorded walk through of the Configurator helped me out a a lot. Thanks!
    Basically what I'm doing here is making it so that if I turn the key off in the car but the PSU shutdown timer hasn't turned the PC off yet that the FB will sense the loss of voltage and pause the music in RR.
    I got it all working using IF input < 3volts then roadrunnercommand_pause but my only concern is that it keeps looping and constantly sending the pause command to RR. Is there a way to make this only occur once?
    Mar 2006
    Quote Originally Posted by bratnetwork View Post
    if input < 3, variable++
    if varaible = 1, pause
    if input >= 3 variable = 0
    Oct 2007
    Haledon, NJ
    i thought of that, but once the variable is set as 1 it will still loop the pause command bc it wont be set back to 0 till I turn the key back on in the car
    i tried to do:
    IF
    variable = 0
    AND
    input < 3
    THEN
    DO pause
    DO variable = 1
    it works if i leave out the "DO variable = 1" line and if i manually change the variable in the config file to 1 then obviously it wont run the statement bc it doesnt meet the criteria which is correct, but as soon as i add in the second "DO" line to change the variable it won't pause on voltage loss
    Oct 2007
    Haledon, NJ
    Code:
    <if fire_on="logic" minimum_delta_vote_time="250" id="RR_PAUSE_LOGIC">
            <boolean_operation type="and">
              <parameter1>
                <boolean_operation type="equal to">
                  <parameter1>
                    <variable do="get" name="Variable_RR_PAUSE"></variable>
                  </parameter1>
                  <parameter2>
                    <number>0</number>
                  </parameter2>
                </boolean_operation>
              </parameter1>
              <parameter2>
                <boolean_operation type="less than">
                  <parameter1>
                    <analogue id="Analogue Input 0" time="0"></analogue>
                  </parameter1>
                  <parameter2>
                    <number>3</number>
                  </parameter2>
              </parameter2>
            <then>
              <do function="external command" functionTargetID="roadrunnercommand_pause" vote_opinion="filler" vote_priority="Medium"></do>
        	<do function="Change Variable" functionTargetID="Variable_RR_PAUSE" vote_opinion="1" vote_priority="Medium"></do>
    		</then>
          </if>
    Oct 2007
    Haledon, NJ
    Any ideas? Am I doing something wrong?
    Mar 2006
    It wont loop, because it only fires when it is equal to 1. Every iteration it will increment.
    So normal operation, it is greater than 3, so variable = 0;
    As soon as input < 3, variable increments.
    If variable == 1, then pause music.
    Because next iteration, input < 3, so increment variable again, now variable is 2. variable no longer equals 1, no other vote is registered. Next time variable is 3, which is not 1 nothing is registered.
    Now when input > 3 again, variable = 0. variable != 1, so no pause vote fired.
    Oct 2007
    Haledon, NJ
    Does my code above look right? when I add in the line about changing the variable mdx won't even open. if i take that line out it works but obviously since its not changing the variable it just loops the pause effect.
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 08:58 PM
  2. RockCar Front End Update 0.0.0.26 800x480 Skin Added
    By Hessian in forum Software & Software Development
    Last Post: 07-25-2008, 03:04 PM
  3. Replies: 65
    Last Post: 07-23-2008, 02:03 AM
  4. MMI eXtnd
    By proTONEd in forum FP Skins
    Last Post: 04-17-2008, 05:26 AM
