Results 1 to 10 of 12
Thread: Skinning question
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Skinning question
    I have Skinned MDX into Digital FX4 skin. It loads up fine when I enter the skin. I am no skinner/coder by any means so here is where I need help. How do I get MDX to either close, or stay open in the tray until I go back to it's skin. Currently, if I enter the MDX skin I made MDX opens up is fine. When I hit "Menu" to go back to RR's main menu it's fine. Now when I go back again it opens a second MDX app and window crashing it. Aslo. Can I change the size of the MDX App window so it doesn't overlay my bottom skin menu commands? Thank you.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Dougw133 View Post
    When embedding it into RoadRunner you need to make sure the application title is correct. If it isn't it will spawn a new one. This is a RoadRunner thing, it happens with GPS programs too.
    To change MDX's size, go into the global graphic properties item of the configurator and you can change it to anything you want.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2007
    PA
    Well I am not doing something correctly because it is not embedding into RR. I follow the usual way I have embedded other apps before and it doesnt seem to be working for me. It opens the MDX as stated above, but not embedded.
    Here is my "Control.skin" file
    Code:
    RoadRunner Skin
    RRScreen Control
    Bottom_Row_OFF.png,Bottom_Row_OFF.png,Bottom_Row_On.png,Bottom_Row_OFF.pngINC
    INC,BottomButtons.txt
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,690,0,44,54,"CLOSE","Close"
    B02,745,0,54,54,"EXIT","Exit"
    B21,0,513,100,86,"EXIT",@LOAD;menu.skin@
    B09,102,513,100,86,"EXITMENU",""
    B,300,512,99,86,"PLAY",@STOP||PLAY@
    B,398,513,101,86,"NEXTTRACK",
    B,203,513,99,86,"PREVTRACK",
    B11,500,513,99,86,"VOL-",""
    B12,596,513,99,86,"VOL+",""
    I01,698,513,107,86,"MASTERMUTE"
    /, A, x, y, w, h, color R;RGB, G, B
    A,0,0,800,600,"WindowsForms10.Window.8.app.0.378734a",,
    END
    My button command in the Skin exectbl.ini
    Code:
    "Load;Control.skin;WindowsForms10.Window.8.app.0.378734a;C:\Program Files\Fusion Control Centre Uber MDX Edition\MDX\Fusion Control Centre UberMDX.exe";WindowsForms10.Window.8.app.0.378734a"
    I'll play around with the global configuration, but it has been crashing the Configurator when I try to open it lately..
    Thanks for the help, alot!
    Mar 2006
    I dont see the title in there at all. It should be "Fusion Control Centre Uber MDX Edition".
    That is the only way RoadRunner embeds...
    Nov 2007
    PA
    Quote Originally Posted by 2k1Toaster View Post
    For button command or for the skin file?
    Nov 2007
    PA
    Wow...I used an old program to find the name of the window and what you see above is what it gave me.. I'm surprised it even opened with that. Using the above it now embeds!!
    Thank you very much Toast...
    Nov 2007
    PA
    And finally!
    Nov 2007
    PA
    Actually I like this setup better! You can't even tell MDX is embedded or exist for that matter. And with the background images being 800X600 just like RR I can use any of the ones I use for the rest of the skin. I know you knew this, you created it! I am just sharing some excitement about MDX and the configurator now that I understand it and can sleep at night!
    Mar 2006
    Glad you got it working.
    And yup you can do anything you want. I think the PSD for those buttons are included too so if you have Adobe photoshop you can change the hue to something more metallic if that is the look you are going for.
    The software is very powerful, and that makes it take a little time to get used to.
    Nov 2007
    PA
    Yeah now that I have got the hang of it I am going to go crazy with Photoshop. Going to match the buttons to the skin I use and add picture icons to them. Thanks again...
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  3. Skinning question
    By ayclens in forum FP Skins
    Last Post: 07-28-2005, 12:57 PM
  4. Photoshop skinning question
    By wysocki in forum RR Skins
    Last Post: 07-26-2005, 05:31 AM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
