Results 11 to 20 of 28
Thread: Temperature reading in Fahrenheit..How?
  1. #11
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Woa lots happened while I was making that post!
  2. #12
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by jss812 View Post
    Ummm, you can click and hold to drag those icons wherever you want so you can read the text. I think the node they are talking about is the little ring. Looks like you right clicked the icon.
    Thats it exactly! I was clicking on the icon, thinking that was selecting what I wanted to link from / to. Right clicking on the "little rings" did the trick! Thanks!
    My Fiero Build Thread
  3. #13
    Nov 2007
    Quote Originally Posted by Dougw133 View Post
    You can click and drag any of those
    Icons" and the the nodes will stay connected unless you manually break them. So I move the icons. To move a fucniton/icon left click on it and it will be come draggable. Don't click and hold like you would in windows. Move them apart so you can work with htem. I made a mistake above. Here is what it should look like.
    Attachment 52738
    You have to click on the NODE, the little black line leading to the circle on the end of a fucniton icon. If you miss you'll get that info box about the fucntion. Nothing will hapen when you click the node until you attatch it to another. It won't do anything graphicaly until the connection is complete.
    So its, LEFT click on the node and RIGHT click to attatch to the next node of choice.
    Oh my, I stand corrected. I was mistaken about the click and hold. Just click is what works.
    As far as linking goes, I work from left to right so I have to right click an output from one node and then left click to the input node of the one I'm going to. Hmmm, if that makes sense.
  4. #14
    Nov 2007
    Quote Originally Posted by JohnWPB View Post
    Are there like many different versions of this software or something? I have the latest version, as when I installed it from the installer, after it was done, got all the balloons in the system tray saying it was updating..... and eventually "all files updated."
    When I follow the above steps, I "find the one I want to change", double click on it and the dialog box has nothing about decimal places, the last entry at the bottom of the dialog is "history to keep".
    I've only used the version they have on their website so I don't know about different versions. Are you sure you went to the top left window and double clicked "Text Labels"? (the icon in there has two "A"s, one larger than the other, in it). So, as soon as you open you're skin in Configurator, you should be able to go there.
  5. #15
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Man, this should not be this difficult hahah! I have created the new function as mentioned above, however it will NOT let me link it. I have tried just about everything, and keep getting the error. I am right clicking the Temp Sensor [Celcius] node (on the right side) and the Celcius to Fahrenheit function (on the left side) and get the error shown.
    Do you have to break the original connection somehow first? Any last suggestions?
  6. #16
    Nov 2007
    Ok, were it me, I would right click the node at the red arrow, then left click at the green. Do the same for the output of that function to the variable.
  7. #17
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    SEVERE BLOND MOMENT! I was right clicking the first node and then doing the same for the second node (right clicking!) Just a matter of getting used to the software I guess.
    On a different note, is there a way to reset the brain without having to unplug it every time and plug it back in. If I run the control center, close it and run it again, it will not work. I have to run it, close it, unplug the brain, plug it back in, and then run the software again.
  8. #18
    Nov 2007
    Just playing with my skin and it works as stated. Have you tried starting that logic from scratch? You know how it's supposed to work so you should be able to drop all your stuff in and link them on the first try.
    I remember having to do that on something but don't know that it was the same as your problem.
  9. #19
    Nov 2007
    Great!
    As far as restarting, I have one computer that needs the brain restart and another one that doesn't. So, if you get it figured out, let me know!
  10. #20
    Fusion Brain Creator
    Mar 2005
    This is a problem... paging nick!
  1. bluetooth woes
    By gentoocar in forum Linux
    Last Post: 12-12-2009, 04:05 PM
  2. Outside Temperature reading
    By Civic03 in forum Software & Software Development
    Last Post: 08-07-2006, 09:30 AM
  3. Phidget Temperature sensor calibration
    By skippy76 in forum Road Runner
    Last Post: 10-05-2005, 11:47 PM
  4. Help prequired for reading serial port data !!
    By tolisn in forum Road Runner
    Last Post: 07-06-2005, 05:04 PM
  5. Replies: 7
    Last Post: 07-01-2005, 04:29 PM
