actually 2 of them.
first, is is it possible to have FB use buttons? not steering wheel buttons or what not but just a plain button and when its pressed, notify the computer. if so how?
and the next one..
same thing with LEDs. is there a way for the FB to tell the compy when an external led had been turned on, maybe like a radar detector for ex?
they call me hack
Independence Auto Tech
http://ctxdesigns.com - web design :)
"Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
1.9in x 2.9in -- 47mm x 73mm
hmm and how would i go about setting one of those up? would they be in the analog or digital?
they call me hack
digital = 1 or 0/ true or fase/5v or 0v
analogue = anything so anything between 5v and 0v
So all digital inputs can be used in an analogue input since both 5v and 0v are in the range of 0v to 5v.
But analogue inputs cannot be used as digital since 3.14v is not 0v or 5v.
So your led is either on or off. That means it can be used on digital.
**EDIT** This is asuming you are soldering directly to the LED pads. If you cant solder or dont want to open it up, then use a light sensor.
A button is pushed or not pushed, which means on or off, so can be used with digital too.
So since they can both be used with digital inputs, they can both be used on analogue inputs.
Our new Fusion Brain will not use any digital inputs since they are so limiting.
so as far as the led goes, i cant actually like splice the LED and then hook it into the board?
they call me hack
lol sorry, im just throwing ideas out.
they call me hack
don't be sorry, I'm just not sure what you mean by "splice the LED"
ah my bad. just instead of actually having to use a sensor to detect when the led is on, could you just somehow splice the + and - of the led into the FB? lol i did a quick paint drawing
they call me hack
