Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: A device I can take apart to simulate steering wheel buttons
  1. #11
    Aug 2006
    Central PA
    I built the circut and when I press button 2. It must go to 0 because the blue button on the brain turns off .
    Also, I remember in version 2 of the software there was a debug mode that showed the values that the brain was seeing in real time. Is there a way to do that in the new version of the software?
  2. #12
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by scotty562 View Post
    Then you hooked it up wrong or used incorrect resistors.
    Take a picture.
    http://www.mp3car.com/vbulletin/fusi...-question.html
  3. #13
    Aug 2006
    Central PA
    I got it figured out. I had one wire infront of the resister rather than behind it. Thanks!
  4. #14
    Mar 2006
    Colorado, but Canadian!
    If the blue light on the Brain goes out, that means you are shorting it out. Read BAD.
    The light should never go out unless you unplug it. If the light goes out you are destroying your brain.
    1.9in x 2.9in -- 47mm x 73mm
  5. #15
    Mar 2005
    Quote Originally Posted by 2k1Toaster View Post
    And you should be thankful we designed a little resiliency into the circuit.
  1. Replies: 437
    Last Post: 04-16-2012, 07:49 AM
  2. My Solution To Steering Wheel Controls
    By jcdillin in forum Input Devices
    Last Post: 12-28-2008, 12:23 PM
  3. Replies: 77
    Last Post: 12-23-2008, 07:29 AM
  4. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 09:33 AM
  5. Steering Wheel button controls
    By StickyBenson in forum Input Devices
    Last Post: 06-23-2007, 03:42 AM
