Results 1 to 10 of 16
Thread: Problem Saving in configuratior
    Jun 2007
    Hello i can not save anything in the configurator. everytime i try to save it comes up with an error saying "error parsing object data to xml." does anyone have any ideas? i have reinstalled the fusion control package from the website mulitple times and have all the up to date drivers...
    Mar 2006
    Colorado, but Canadian!
    Can you post the error and the details please. Screenshot would be nice too.
    What sort of system is this running on?
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2007
    I am running windows xp professional on a via mini board 1.2ghz & 1g ram. here is a shot screen shot of the error.
    Mar 2006
    Can you post steps you are doing to get this error so I can reproduce it please.
    What the error means is that there is some character like a "<", or a ">" that is being put in your file that is invalid.
    Before you save, copy the textual version into a new file and post that please.
    Jun 2007
    alright well i guess that makes sense...
    here are the steps i have taken:
    1. open Fusion control cetre uber mdx edition
    2. click on ninja kity wizard of doom
    3. hit next
    4. type 1 for number of fusion brains and hit next
    5. click on button to find fusion brain (mine is one of the original versions) and then click next
    6. type 5 for the number of outputs
    7. hit next again since i dont need to change any of the types to momentary
    8. leave number of inputs 0 and hit next again
    9. click on default template and leave controlling digital outputs selected and hit next
    10. click finish and let it configure the settings
    11. click on save (i was changing a bunch of other settings previously but i realized that i cant get it to work either way and that i am getting the same error message when i try to save no matter how much i change)
    here is the code
    <?xml version="1.0" encoding="utf-8" ?>
    <FusionControlCentreConfiguration version="3.0" author="Ninja Kitty Wizard of Doom" date_created="Tuesday, December 23, 2008 at 10:40:42 AM" last_modified="Tuesday, December 23, 2008 at 10:40:43 AM">
    <require>
    <!-- Begin Function Instances -->
    <!-- End Function Instances -->
    <!-- Begin Fusion Font Instances -->
    <font name="Verdana" originalSize="25" font_config="content\fonts\Verdana.xml"></font>
    <!-- End Fusion Font Instances -->
    </require>
    <speech enabled="false" global_politeness="true">
    <!-- Begin System Speech Instances -->
    <!-- End System Speech Instances -->
    <!-- Begin System Speech Definition Instances -->
    <system_definitions>
    </system_definitions>
    <!-- End System Speech Definition Instances -->
    <!-- Begin Custom Speech Definition Instances -->
    <custom_definitions>
    </custom_definitions>
    <!-- End Custom Speech Definition Instances -->
    <!-- Begin Custom Query Instances -->
    <custom_queries>
    </custom_queries>
    <!-- End Custom Query Instances -->
    </speech>
    <general>
    <!-- Begin Remote Control Configuration -->
    <remote status="disabled" user_name="default" port="4242"></remote>
    <!-- End Remote Control Configuration -->
    </general>
    <graphics>
    <!-- Begin Global Graphic Settings -->
    <main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="False" MinimizeToSystemTray="True"></main_display>
    <!-- End Global Graphic Settings -->
    <!-- Begin Background Images -->
    <background_image style="stretch" imagefilepath="content\images\background_images\ba ckground.jpg" page="0"></background_image>
    <!-- End Background Images -->
    <!-- Begin Static Images -->
    <staticimage>
    <image path="content\images\static_images\logo.png"></image>
    <display size="556,27" location="123,44" page="0" z_order="0.9"></display>
    </staticimage>
    <!-- End Static Images -->
    <!-- Begin Variable Location Images -->
    <!-- End Variable Location Images -->
    <!-- Begin Graph Instances -->
    <!-- End Graph Instances -->
    <!-- Begin Display Buttons -->
    <button id="NINJABUTTON_Digital_Output_0" enabled="yes" function="trigger output" functionTargetID="Digital Output 0" vote="attached" vote_opinion="on" vote_priority="Medium">
    <images imagePrimary="content\images\button_images\button_ down.png" imageSecondary="content\images\button_images\butto n.png" imageDisabled="content\images\button_images\button .png" imagePushed="content\images\button_images\button_d own.png"></images>
    <display size="230,70" location="37,119" page="0" z_order="0.9"></display>
    <vote_options minimum_delta_vote_time_down="20" ></vote_options>
    <text font="verdana" font_size="25"></text>
    <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 0"></text>
    <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 0"></text>
    </button>
    <button id="NINJABUTTON_Digital_Output_1" enabled="yes" function="trigger output" functionTargetID="Digital Output 1" vote="attached" vote_opinion="on" vote_priority="Medium">
    <display size="230,70" location="287,119" page="0" z_order="0.9"></display>
    <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 1"></text>
    <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 1"></text>
    </button>
    <button id="NINJABUTTON_Digital_Output_2" enabled="yes" function="trigger output" functionTargetID="Digital Output 2" vote="attached" vote_opinion="on" vote_priority="Medium">
    <display size="230,70" location="537,119" page="0" z_order="0.9"></display>
    <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 2"></text>
    <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 2"></text>
    </button>
    <button id="NINJABUTTON_Digital_Output_3" enabled="yes" function="trigger output" functionTargetID="Digital Output 3" vote="attached" vote_opinion="on" vote_priority="Medium">
    <display size="230,70" location="37,219" page="0" z_order="0.9"></display>
    <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 3"></text>
    <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 3"></text>
    </button>
    <button id="NINJABUTTON_Digital_Output_4" enabled="yes" function="trigger output" functionTargetID="Digital Output 4" vote="attached" vote_opinion="on" vote_priority="Medium">
    <display size="230,70" location="287,219" page="0" z_order="0.9"></display>
    <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 4"></text>
    <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 4"></text>
    </button>
    <!-- End Display Buttons -->
    <!-- Begin Multi Images -->
    <!-- End Multi Images -->
    <!-- Begin Text Labels -->
    <!-- End Text Labels -->
    </graphics>
    <io>
    <!-- Begin Fusion Brain Instances -->
    <brain id="My Fusion Brain 0" version="3">{43b36ca4-5c35-485b-82f4-3957e44299b5}</brain>
    <!-- End Fusion Brain Instances -->
    <!-- Begin Timer Setup -->
    <timer id="input" interval="75"></timer>
    <timer id="output" interval="100"></timer>
    <timer id="gui" interval="50"></timer>
    <timer id="logic" interval="50"></timer>
    <!-- End Timer Setup -->
    <!-- Begin Digital Output Instances -->
    <iochannel id="Digital Output 0" port="0" brain="My Fusion Brain 0" type="digital_output">
    <defaults defaultstate="off"></defaults>
    </iochannel>
    <iochannel id="Digital Output 1" port="1" brain="My Fusion Brain 0" type="digital_output">
    </iochannel>
    <iochannel id="Digital Output 2" port="2" brain="My Fusion Brain 0" type="digital_output">
    </iochannel>
    <iochannel id="Digital Output 3" port="3" brain="My Fusion Brain 0" type="digital_output">
    </iochannel>
    <iochannel id="Digital Output 4" port="4" brain="My Fusion Brain 0" type="digital_output">
    </iochannel>
    <!-- End Digital Output Instances -->
    <!-- Begin Analogue Input Instances -->
    <!-- End Analogue Input Instances -->
    </io>
    <logic>
    <!-- Begin Logging Setup -->
    <all_logging>
    </all_logging>
    <!-- End Logging Setup -->
    <!-- Begin Variable Declarations -->
    <all_variables>
    </all_variables>
    <!-- End Variable Declarations -->
    <!-- Begin Logic Declarations -->
    <all_statements>
    </all_statements>
    <!-- End Logic Declarations -->
    </logic>
    </FusionControlCentreConfiguration>
    Mar 2006
    Ok, well the only change has been to the Fusion Brain and its version. If you look in the brain instances under io, you see it is {something}. try removing those brackets and saving. to do that edit your rbain instance.
    I will try and see whats up when I get back to my computer, currently just on my phone. Let me know if that changes anything.
    -- Nick
    Fusion Control Centre
    Sent from my HTC Touch Pro
    Jun 2007
    Alright well now i can alteast save that part... but now when ever i try to edit graphical properties i get the same parsing error when i click save in the graphical properties window, and also when i try to change the default state of the outputs in the digital output window.
    Mar 2006
    I have tried to make the same thing happen and I cannot reproduce any of it. Even with the brackets, mine saves just fine and works perfectly.
    Are you using any non-US English regional settings?
    Mar 2006
    Replace your configurator exe with this one: http://www.fusioncontrolcentre.com/T...nfigurator.exe
    This should give you a second error box after the first one. I need the details from that box since I cannot reproduce it on my end.
    Jun 2007
    Here is a screen shot of the error window
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
