Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: V4 PWM firmware update
  1. #21
    Sep 2009
    Firmware update issues
    I've just received my V4 brain, and it does not seem like PWM is working, so I want to update the firmware.
    Now, how do I do that?
    If I hold down the black button (not red) and apply power, Windows does not detect any USB insertions. (and the firmware update program cannot see anything either)
    Ok, then I release the button, and the brain is detected by Windows.
    The firmware program doesn't detect the brain now either.
    If I try to install the "bootloader driver", I am told the inf file does not contain information about my device.
    The VID/PID data for my brain are: USB\VID_04D8&PID_000E
    The .inf does not contain that PID. I tried adding it manually, and now I could install the bootloader driver. Repeating the above steps (apply power, holding down button, etc), the update program still cannot see the brain, however.
    So - how do I update the firmware??
    System:Windows XP 32-bit.
  2. #22
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by RBJensen View Post
    Is this the first one, or the second one? If you ordered before Boxing Day, you have 2 in the mail. The one from the first package is defective. The second package has the newest firmware and bootloader. PWM should work out of the box too.
    Easy way to check is plug it in and see if it reports analogue voltages above 5v. If so, it is the bad old one.
    We ask that you send the old one back once you get the new one. If this is the new one, then something is amiss and I can try to help out.
    1.9in x 2.9in -- 47mm x 73mm
  3. #23
    Sep 2009
    I ordered two brains on November 20th, (Order #616) - ), so I suppose I must have received some bad ones?
    Not sure - the FBDemo program doesn't show any analog voltages with all outputs off.
    However, if I turn on several outputs, the analog inputs claims that several of them have a varying amount of voltage applied. I don't suppose that is the way they're meant to work...
    My brains were sent with a tracking number which was first registered on December 26th, but didn't get shipped until January 1st.
    I did get a second USPS notification on January 7th (in addition to the one on December 26th), but that ones status has not been updated at all, and is still simply "Electronic Shipping Info Received" - so perhaps you have not shipped my replacements yet?
    I'd pretty much like if you'd sent some information about those defective brains - your USB communication skills are top class, but your mail ditto could be improved ;P
  4. #24
    Mar 2006
    Everything notified on the 26th (saturday), was shipped the 28th (monday). Same day the second shipment notification went out, the boards went out. USPS has the worst "tracking" in the world. I have had things delivered when it still says "USPS was notified of shipment on blah day but doesnt mean we have it"
    Anyways, if it is from the first one, then yes it is defective. The turning on outputs and getting inputs is not normal for sure.
    The defective brains were flashed with a firmware that I had supposed was the most recent and full version, however it was not and was actually corrupt. This corrupt firmware also does not include a USB bootloader. So the only fix is to reflash using a real programmer, which I have done and mailed out to those affected, such as yourself.
  5. #25
    Sep 2009
    Roger.
    The first shipment took around two weeks to get here, so let's see if the second shows up in a week or two.
    TTYL.
  6. #26
    Sep 2009
    What is the "pinout connection" for the ICSP header?
  1. 95 Lexus SC300 - 0l33l's "Project SC300"
    By 0l33l in forum Worklogs
    Last Post: 01-14-2010, 08:55 AM
  2. Keyboard and Bluetooth Dongle Firmware Update
    By DjBac in forum Input Devices
    Last Post: 08-24-2009, 07:22 PM
  3. Centrafuse 1.45 Update
    By veetid in forum Centrafuse
    Last Post: 12-13-2007, 10:27 AM
  4. Centrafuse 1.44 Update
    Last Post: 12-08-2007, 05:59 PM
  5. Centrafuse 1.42 Update
    Last Post: 11-25-2007, 04:41 PM
