Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Frequency to voltage board
    Fusion Brain Creator
    Mar 2005
    Hey boys and girls...
    I'm designing the frequency to voltage output board. The specs so far:
    1-channel
    67hz/volt
    ~4000rpm/volt
    Works with any V3/V4 board
    ~$15 per board.
    Any changes before I send it out for production?
    Dec 2007
    Now you tell me.. After I have already submitted mine. I could have let you do all the work and I could have been lazy and waited. Cool if mine have a problem I can order 2 from you and not have to re-submit.
    Mar 2005
    Quote Originally Posted by RonS View Post
    I'm curious about yours. Can you email the schematic to fusioncontrolcentre@gmail.com?
    Dec 2007
    You've got mail..
    Sep 2007
    Export, PA
    this would be quite useful for figuring out engine speed (based on tach signal) and vehicle speed (based on speed sensor)
    you have my attention sir
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    Aug 2008
    Decatur Illinois
    Can the circuit be modified to have another range? My max RPM will be 4,000. If I could change a resister and get 1,000 rpm per volt it would be ideal.
    Sep 2007
    Export, PA
    my question is, how accurate will it be, like within how many RPM?
    Mar 2005
    Quote Originally Posted by FredWorrell View Post
    yes, you can.
    anyway, in current form it's pretty accurate.
    brain's good for about 0.01 volt
    1v = 4000 rpm
    so it'd be good to about +/-40rpm
    that's a whole lot better than factory
    Sep 2007
    Export, PA
    When will it be available for purchase good sir? I havn't seen nick on MSN in a while to talk to him...
    I'm gonna be ordering a bunch of stuff soon here.
    Do you think that you could get me a schematic with component info for a driver board so that I can power stuff in my car without using relays? I need to power up to 30A circuits... I read up some on some MOSFET's, but I'm no engineer, and I don't fully understand how that jazz works.....
    Hell, i'll pay you if i have to...i just want to be able to power some things using solid state electronics instead of relays...
    PM me what it's gonna take to get you to do it. I can lay it out as long as i know what components are needed and what is wired to what... I use ExpressPCB to lay stuff out, which is sufficient for what I need usually...
    Mar 2005
    we have 40A driver boards coming, compatible with on/off or PWM.
    should be available for purchase in a couple weeks.
  1. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 10:42 PM
  2. Lilliput Button Board IR Extension
    By FLESIK in forum LCD/Display
    Last Post: 02-13-2007, 03:58 AM
  3. Powering car from a 13.8V power supply ok?
    By PURDooM in forum Power Supplies
    Last Post: 06-12-2006, 12:56 PM
  4. OPUS 150 voltage tolerances
    By Mr.Mp3 in forum Power Supplies
    Last Post: 06-03-2006, 09:42 PM
  5. Need help understanding efficiency and voltage regulation
    By sansoo24 in forum Power Supplies
    Last Post: 04-22-2005, 03:45 AM
