Results 1 to 5 of 5
Thread: Yaw Rate/Gyro Board?
    Fusion Brain Creator
    Mar 2005
    Some of you have expressed interest in a gyro/yaw rate board.
    If we could find 10 people willing to buy, we'll send a board based on the LISY300AL out for manufacturing.
    http://www.st.com/stonline/products/.../lisy300al.pdf
    It'd be about $25. Post here if you'd want one.
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    I've been using a 75 deg/sec yaw sensor because I need the sensitivity. The guys that have inverted pendulum robots usually use one gyro and two accelerometers to determine the angle. The gyro provides quick reactions, and the accelerometers calibrate where vertical is, and eliminate the drift and bias that a gyro has. They get coupled with a Kalman filter. You might want to look into building a board with a single or dual axis gyro and a 2 or 3 axis accelerometer all on one board. Just an idea.
    Mar 2008
    I want one.
    Mar 2009
    Florida
    I want one also.
    Newbie Flyingboat's Avatar
    Apr 2007
    Sold.
  1. USB Controlled Relay Board or general output
    By 2k1Toaster in forum Hardware Development
    Last Post: 05-29-2007, 12:40 PM
  2. Lilliput Button Board IR Extension
    By FLESIK in forum LCD/Display
    Last Post: 02-13-2007, 03:58 AM
  3. PC Board Etch on Plexi
    By Sillydipstixs18 in forum General Hardware Discussion
    Last Post: 09-21-2005, 07:12 PM
  4. Replies: 4
    Last Post: 05-04-2005, 12:24 PM
