Results 11 to 20 of 23
Thread: steering wheels control for chrysler
  1. #11
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    Quote Originally Posted by greenman100 View Post
    can't use the CAN-bus with the FB
    so none of the chrysler car you can use the FB becuase it uses can-bus? Most all car use some kind of system like that. gmc, MBenz,bmw ect..
  2. #12
    Apr 2007
    Quote Originally Posted by customaudioman View Post
    Correct, if you tap into the CAN-Bus, you may cause unwanted results with the many onboard computers in your car.
    It can potentially cause a no start condition.
  3. #13
    Mar 2006
    Colorado, but Canadian!
    You may be able to get to the actual circuit behind the buttons and disable the CAN part altogether. Chop the circuit and wire the buttons straight to the output via the same resistor pattern in the honda.
    But just like reromero said, tinkering with the CAN system at all can immobilize the entire car and/or cause permanent damage.
    Should have just not given up the honda
    1.9in x 2.9in -- 47mm x 73mm
  4. #14
    Oct 2005
    east coast
    Quote Originally Posted by 2k1Toaster View Post
    Okay guys thanks for all your help. I guess I wont be using the fusion brain for this car. The honda I had cant compare to the car I have now. I never thought I would buy american and be happy with it. thanks for all your help.
  5. #15
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    I have yet to test this, but I have a theory.
    If you get the SWI-CAN adapter from PAC, you should be able to tap into your can-bus +/- wires and run those to the SWI-CAN. Then the SWI-CAN should output a usable signal that you can interface with the Fusion Brain. If you already have the FB then the PAC adapter is the only other thing you need to purchase. I haven't tried it yet because I don't want to fork over the dough for the FB and the PAC adapter just for steering wheel controls on my VW.
    Any thoughts?
    CarPC:
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
  6. #16
    Dec 2005
    Grand Blanc, MI
    Bumping this for an answer to the above. ^
    CarPC:
    Sound System:
  7. #17
    Low Bitrate rtgree01's Avatar
    Aug 2007
    STL
    Or if you are interested in a can bus adapter, canusb is a device that hooks directly into the can bus. I have decoded the messages on the can bus that correspond to the steering wheel controls on my dodge charger.
    I've even written a rr plugin that uses the steering wheel controls....
    ryan
  8. #18
    Oct 2005
    east coast
    where can I get one of these and how much?(canusb)
  9. #19
    Dec 2005
    Grand Blanc, MI
    x2
    Never head of such a thing. Need more info please!
    CarPC:
    Sound System:
  10. #20
    Aug 2007
    STL
    the manufacturer's web site is http://www.canusb.com You have to go through one of their distributors. Last I heard, the distributor's website said the device was out of stock but that that was not up to date. When I bought mine, it was about $150. Expensive, but you can do some neat things with it....
    Ryan
  1. Replies: 3
    Last Post: 05-06-2008, 09:25 AM
  2. Steering wheel control and durability
    By bimmerpc in forum General Hardware Discussion
    Last Post: 11-01-2005, 03:01 PM
  3. Acura steering wheel volume control implementation
    By jayearl in forum Input Devices
    Last Post: 09-16-2005, 04:30 PM
  4. Wireless control for steering wheel
    By DodgeCummins in forum General MP3Car Discussion
    Last Post: 02-15-2002, 02:14 PM
