Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: V4 issue in extreme cold temperatures
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    Spring is approaching, so over the last few days I put the steering system back into the tractor. I took it out for some tuning today (first time with the v4 FB) and after about 5 minutes it locked up on me. The FB is being powered via USB, and I have no reason to believe the USB cable came loose. Disconnecting and reconnecting the DC jack did not resolve it. I had to disconnect/reconnect the USB connection to get control of it again.
    I only have relays on two of the FB outputs. One was on at the time of the lock.
    Do you have (or have you looked into) some kind of watchdog process on the PIC? If there was a watchdog, would that also kill the handle in the driver, thus requiring a software disconnect/reconnect to get control of it again?
    Should I try changing the jumper so that the PIC is powered by the DC jack instead of USB?
    -Lance
    Fusion Brain Creator
    Mar 2005
    We've played with watchdogs in the past, I can put up a firmware update if you like.
    I have no idea what's going with your tractor. The PIC must be still picking up noise over the 12v line. Are you powering it the same way you powered the V3 that didnt lock up?
    Aug 2003
    Iowa
    Sure, I'll try a watchdog. Is there any reason that a watchdog would be a bad thing, or why isn't it part of the standard firmware?
    In order to get the v3 to be stable in this tractor, I had to power it with an inverter, then to a 12vDC power brick. I had hoped that the larger capacitors on the v4 would resolve this. My jumpers are currently set so that the PIC is powered from USB. Since I'm using USB power, those bigger caps probably aren't doing anything for me, are they. I'll try moving the jumpers over to see if that resolves this. I'll take the tractor out for another test tomorrow.
    The only major electrical noise I can think of would be the solenoid valve I'm using to control the steering. That circuit gets power direct from the battery, with ground going to the engine block. The 12v coming into the DC jack on the FB is coming from a circuit on the main fuse panel. That circuit also powers my GPS receiver, which has worked fine all through this. I'm pretty sure that receiver is designed to accept any kind of electrical crap that could possibly be seen. It's a pretty rugged unit, and probably has some reasonably large caps inside.
    -Lance
    Aug 2003
    Iowa
    I moved the power jumpers over to the DC powered position and took the tractor out again today. It ran for about 15 minutes, then locked up on me. I power cycled it, and it continued to work for another couple minutes before I parked the tractor back in the shed. I took a pic of what the FB looked like while locked, not that it will tell you much. I'll get that posted later tonight when I get home.
    Aug 2003
    Iowa
    (removed broken links)
    Here are my pics from today. Last pic shows the locked up state, which really doesn't mean much. I have outputs 15 and 16 oscillating just so that I can see when there is IO happening. Outputs 12 and 13 each go to a relay, which control solenoids on each side of the hydraulic valve, which is under the plastic box.
    One of these days I'm going to throw an o-scope on the +12 side coming in to the FB to see how much of a power dip it is seeing when a relay trips and a solenoid powers up.
    Jun 2008
    Georgia, USA
    Is that the motor underneath the plastic box? If so, you may be getting too hot.
    Thanks,
    Dan
    Aug 2003
    Iowa
    Yes, that is the engine. Space is at a premium in the cab, and there was an empty spot under the hood. Heat may become an issue this spring/summer, but it certainly isn't right now. I'm in Iowa and it is well below freezing here. In my testing, I haven't been working the engine hard enough to start warming up the engine bay much.
    Sep 2005
    Australia
    Ohhh, did you say well below 0!. How much below. The xtal on the board might have a standard temperature range not extended.
    I had a similar problem when I was doing some capability studies for parking meter coin entry systems for Canada. The controller board actuall stopped working at below -10c (degrees) once the xtal was warm again it continued working.
    What you could do is when it stops working again, try to heat up the xtal to see if it resumes operation, if so then you can either keep the xtal warm or upgrade to a extended temperature xtal. The extended temperature ones go down to -40c
    FYI, these are the typical ranges for xtals
    -40C - +85C // Extended temp range
    -20C - +80C
    0C - +70C // Standard temp range
    If the above test fails, check the specs of the Microcontroller (though I found the micro is more tolerant than the xtal)
    Hope this helps
    Aug 2003
    Iowa
    Well the board was 60 degrees F in the shop before I took the machine out for testing. The FB is in a plastic box which I maybe had the lid off once before it locked up. Outside temp was about 14 degrees F, but when it locked, the engine had been on for a bit so the air around the plastic box would have been slightly warmer than ambient temp. Probably at freezing or just above. Once I power cycled the FB, it kept working for the rest of my testing, which was only a few more minutes.
    What is the xtal? Is that the 5v regulator?
    -Lance
    Sep 2005
    Australia
    Oh sorry, thats the oval silver thing right next to the bootloader button. xtal actually stands for "crystal" its job is to oscillate the microchip at 20.0Mhz (you should see it printed on top of it)
    If ambient is 14C F, thats about -10C celsius
    Thats means if the Xtal was a "Standard temperature range" type it would be out of spec.
    Sorry the above ranges were in Celsius, metric down here
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 01-07-2012, 01:29 AM
  2. My RR/DFX 4.0 100% CPU usage issue
    By Minoritydan in forum RR Bug Tracker
    Last Post: 12-23-2008, 12:40 PM
  3. No audio after resume from hibernate issue - almost fixed - Help me finish?
    By Trin in forum Software & Software Development
    Last Post: 07-26-2008, 07:35 AM
  4. M4-ATX Power On Issue
    By PacketSniffer in forum Power Supplies
    Last Post: 04-24-2008, 10:00 PM
  5. Replies: 0
    Last Post: 09-04-2007, 10:56 PM
