Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: Having a little trouble with output.......
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Ok can you give this exe a try please: http://www.fusioncontrolcentre.com/T...werTest001.zip
    Just replace the exe in your install directory with this one and see how it goes.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Sep 2007
    Dawson, IL
    Acts the same as the earlier version I had dated 2-25, it is actually now starting the output when MDX is started and will not shut it off until power is removed from the brain - made sure output default was off
    If anyone gives me a rev - I give them the Bird
  3. #13
    Mar 2006
    Quote Originally Posted by Rick99TAWS6 View Post
    Are you sure you have your FB version set correctly in the Configuration File?
  4. #14
    Newbie ATT41's Avatar
    Dec 2008
    Australia - Brisbane
    I'm running XP, I will try the new exe today,
    as for the configuration file, I'm sure it is still 3.0 because I havn't changed it at all. It is the exact same config file from previous drivers. Should I try making a new MDX file from scratch maybe?
    [H]
    ____╔══════╗____
    OOO/ATT41\OOO
  5. #15
    Mar 2006
    Quote Originally Posted by ATT41 View Post
    If it is the same file then it is wrong. The default is version 4. If you are using a version 3 board it must explicitly say so in the brain instance.
  6. #16
    Mar 2006
    There is also an update that just went out that changes some of the Configurator brain instance handling. So you may want to do an update before you change the version number if you are using the Configurator.
  7. #17
    Dec 2008
    I mean my config file is the exact same that I have been using for the last 6 months. I will confirm that the config file is for version 3 also today, will let you know.
    [H]
    ____╔══════╗____
    OOO/ATT41\OOO
  8. #18
    Dec 2008
    Quick update, I have viewed my config file and the first 2 lines are as follows:
    <?xml version="1.0" encoding="utf-8" ?>
    <FusionControlCentreConfiguration version="3.0.0.0"
    I assume this means it should work with boards > V3?
    OK, So I have tried the new exe file and there is a difference with the output status. I tested this with a virtual brain. The outputs will turn off when going into standby, but upon returning from standby, the outputs are still off. The screen is also broken until I resize the MDX program, screen shots below:
    This is with outputs on, about to click standby:
    This is resuming after standby; outputs are still off and MDX image broken:
    This is the MDX image showing after resize:
    [H]
    ____╔══════╗____
    OOO/ATT41\OOO
  9. #19
    Sep 2007
    Dawson, IL
    Quote Originally Posted by 2k1Toaster View Post
    Thought it defaulted to V4 during configurator setup after selecting the V4 brain it puts 4 in the version number, but looking at the generated xml I am seeing V3 in there so I will play with that a little - update tried to change the XML to v4 but had no effect on problem.......
    When did that update get released?? I downloaded one yesterday morning and reinstalled it yesterday afternoon....
  10. #20
    Mar 2006
    Those first lines have nothing to do with the Brain version. They are the minimum MDX version that the configuration file needs to run.
    You need to put version="3" in your FB instances under IO.
    There have been about 3 since yesterday morning.
  1. Replies: 7
    Last Post: 01-03-2009, 02:52 PM
  2. using amp output to input?
    By Xprime4 in forum Car Audio
    Last Post: 12-21-2007, 10:26 AM
  3. M-Audio Fast Track Pro: 2.1 Output Possible?
    By speedycheater in forum General Hardware Discussion
    Last Post: 12-10-2007, 02:07 PM
  4. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 03:48 PM
  5. No lcd output
    By JettaMP3 in forum General Hardware Discussion
    Last Post: 03-12-2001, 03:27 PM
