Sorry I quoted the wrong person there.Above with the xml schema and then version, that is what I was referring to. That is not the correct way to do it.
However, your way with...
is the correct way if you have a V4. That GUID inbetween is actually depreciated as well, you can make that "penguin" if you wanted, it will work the same now.
LinkBack URL
About LinkBacks
